help to finish my d16a1 dohc
i have a d16a1 and a 88 crx. i need a few things and wonderin off of what other car i can use them from. like teg or civic crx so and so. or can i use wat i need off a single cam crx??
the parts i need. and if u guys can give me a hand tell in me wat cars i can use them from thanks.
motor mounts
shift links
alexs
motor mounts
shift links
alexs
So your trying to put a d16a1 into a crx? If so your gona have to do some custom fabrication on your mounts because the d16a1 isnt meant to drop right into a crx/civic its for an integra. Dohc zc on the otherhand is a straight swap into a crx.
The D16A1 is the dohc engine out of a "first" gen Integra. It will bolt into a first gen crx (84-87), "not" the 88-91 series
I personally would never bother with such a swap. For the time and trouble it would take to custom fab out new engine mounts and mess with the wiring, you could simply p/u a B18A swap with a mount kit and drop it in, and, make more power....plus the engine is stronger
Yak BallZ
16
May 8, 2005 01:11 AM
I8ayellowcrayon
Jun 18, 2003 10:11 PM
