crx si with a b16a probelms just bought!
Old Jul 29, 2011 | 08:51 AM
19crx93's Avatar
Default crx si with a b16a probelms just bought!
ok so i just bought a crx with a swapped b16a.
the car is all jimmy rigged and i am now just finding problems.
the problem is that i dident do the swap and dont really know what the guys did.
sometimes when im driving the car will not go passed 4000 rpm while jumping all over the place. kinda like i have 2-step but i dont and can never go pass4000 rpms. the wiring is a mess and i belive that is the problem, or the vacume lines. anyone else have this problem? and anyway i can get all the wires right or get a diagram for this swap. please help.
Old Jul 29, 2011 | 11:46 AM
dephtone's Avatar
Default Re: crx si with a b16a probelms just bought!
Is your check engine light on? My assumptions would say yes, but you never know.
If it is, check to see which codes are being thrown and begin your troubleshooting from there.
Old Jul 29, 2011 | 01:11 PM
crx_si-r's Avatar
If you cannot go passed 4k then your car is most likely in limp mode. This is a safety feature that will still allow you to drive, but will keep the damage to a minimum by limiting the motor function. You should also have a check engine light, find out the code. You Problems will most likely be in the wiring.
Old Jul 30, 2011 | 09:25 AM
91_rex_ls-vtec's Avatar
my car did this too wouldnt go past something like 3600 rpm. the ecu was fried. replaced it with a chipped ecu and i was reving to 9K.
B16aSir2
Dec 23, 2005 06:22 PM
B16aSir2
10
Dec 23, 2005 10:59 AM
AllMotor_B20_Hatch
Feb 6, 2005 07:27 PM
smokinvtecCRX18
15
Mar 30, 2003 01:10 AM
CivicSiR7
Dec 15, 2002 09:05 PM
