95 Accord Setting TDC after removing timing belt
Old Jul 28, 2011 | 10:08 PM
jwonger's Avatar
Default 95 Accord Setting TDC after removing timing belt
So I made the rookie mistake of removing the timing belt prematurely after taking off the crankshaft pulley bolt. I was thrilled after finally taking off the bolt that I didn't even think of putting it back in so I can re-adjust the camshaft pulley at TDC.
Is there a process in which I can achieve TDC?
I can move the crankshaft pulleys to TDC but I cannot move the Camshaft to TDC. I can only turn it an inch or so, but irregardless it moves back into it respective place.
Any help would be greatly appreciated.
Old Jul 28, 2011 | 10:28 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 95 Accord Setting TDC after removing timing belt
****ing noobs not even looking at the FAQ...
Here's your bone.
TouringAccord only went through the trouble of documenting the whole process, https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/.
You checked off that you had read the rules, show some semblance that you did.
Old Jul 29, 2011 | 12:12 AM
jwonger's Avatar
I read that.
I went back to step 12 so that I can "make sure [the] camshaft pulley is still set so that piston no.1 is at TDC."
The camshaft pulley was not at TDC and so I tried to rotate it but was unable to. I can only turn it an inch or two before it springs back to its previous position.
Sincerely,
xxxxing noob
Old Jan 18, 2024 | 12:23 AM
RJamesS's Avatar
I read that.
Sincerely,
xxxxing noob
how did you rotate your cam to get it to tdc. same problem cant find answer anywhere.
Old Jan 18, 2024 | 04:23 AM
hondamark35's Avatar
It's a bit of a long shot asking a user who only ever posted 3 times 13 years ago.
Here's an alternate method I have used for getting the cam in time when it wants to spin on you.
-let the cam settle into position before TDC (clockwise) so the spring pressure from the valves is stable.
-turn the crank to about the same number of teeth before TDC as the cam is.
-install the belt and pre-load the tensioner
-rotate the crank forward to TDC and check the cam alignment. If it's off a tooth or two, just mark the belt and pulleys (I like to use a white paint pen) and make a correction when you put the belt back on following the same steps.
jazyjeff
Jun 21, 2008 06:18 AM
xiLLtegRax
May 22, 2006 04:51 AM
Shady Hills
Jul 24, 2004 09:40 PM
