Honda S2000 Honda S2000
green key flash
Old Jul 28, 2011 | 07:39 PM
dc2go's Avatar
Default green key flash
picked up a "project car" anyhow, when tested with starter fluid. it started up find then dies. before that he did mention theres no gas left. theres no cat so it was loud couldnt tell if the engine was smooth. i end up buying it still. today i added gas and battery. cranks up and you can hear the exhaust but dies right away. from what i've googled. it could be the main relax (couldn't find it) anyone got the location? it also could be the immobilizer since the green key does flashes after i removed it but doesn't show when key is in..is that normal?
Old Jul 29, 2011 | 06:32 AM
hatrickstu's Avatar
Default Re: green key flash
starter fluid?
Old Jul 29, 2011 | 07:40 AM
White Smoke's Avatar
i my honda
Global Mod
It's not the immobilizer if it cranks. The flashing green key you are describing sounds normal. When is the last time this car ran? Where did you spray the starting fluid when you started the car originally? Does it run for any longer, shorter or the same as when you were able to get it started with the help of the fluid?
I would hope you have already changed the oil before trying to start it if it has sat for a long time?
Originally Posted by hatrickstu
starter fluid?
It's just like strong carb cleaner, just think of it as spray gas.
Old Jul 29, 2011 | 03:14 PM
dc2go's Avatar
started the car at the old owners place. we only tried it once and it was loud cause there was no cat. stayed on about 2 sec. he also said theres no gas. well, today i removed the main relay and just ordered one on ebay. hopefully this is the fix.
Old Jul 30, 2011 | 12:48 AM
dagle's Avatar
Compression numbers?
Old Jul 30, 2011 | 11:43 AM
dc2go's Avatar
can't doesn't stay up long enough for it to warm up but might have to check still. don't even have the tools...yet
keico
Honda CR-V & Element
36
Jul 26, 2011 01:55 PM
TurtlePowerCivic
Feb 3, 2007 05:06 PM
See Are Ex
Dec 31, 2005 09:43 AM
smash fascism
21
Nov 6, 2005 03:52 PM
LillDragun
May 11, 2002 09:08 AM
