ERL SLEEVED GSR ENGINE
I have decided to part out my car and go a different direction.
ERL SLEEVED GSR ENGINE - $3000
This motor has approx. 2000miles .
Engine specs are as follows:
ERL Sleeved B18C Block
84MM Bore
Wiseco Pistons
Eagle Rods
Balanced GSR Crankshaft
ARP Main Studs
ARP Head Studs
ACL Race Main and Rod Bearings coated by Calico Coatings
Cometic Head Gasket
Ported GSR Head
GSR Camshafts
Supertech Std Size Valves
Supertech Valve Springs and Titainum Retainers
Approx Compression ratio of 9.2:1
Intake Manifold, Fuel Injectors, and Fuel Rail are NOT included, but can be purchased separately. Motor will be a bare long block. Will not come with any sensors or distributor.
84MM Bore
Wiseco Pistons
Eagle Rods
ARP Main Studs
ARP Head Studs
Cometic Head Gasket
Ported GSR Head
GSR Camshafts
84MM Bore
Wiseco Pistons
Eagle Rods
ARP Main Studs
ARP Head Studs
Cometic Head Gasket
Ported GSR Head
GSR Camshafts
84MM Bore
Wiseco Pistons
Eagle Rods
ARP Main Studs
ARP Head Studs
Cometic Head Gasket
Ported GSR Head
GSR Camshafts
BEfab
Oct 1, 2011 01:10 AM
BEfab
Jul 14, 2011 01:07 PM
