fs civic/acura/dsm/2jz stuff, all misc stuff
Old Jul 28, 2011 | 09:54 AM
nasteboyii's Avatar
Default fs civic/acura/dsm/2jz stuff, all misc stuff
i have a massive amount of stuff for sale, most i just want this stuff gone, but there are a few things i need at the moment ill trade or trade plus cash
haltech 2000 for supra 2jz setup (i would love one of these )
If you dont see a price make offer, and ill probably take it. will ship at buyers expense
B series turbo kit complete charge pipes, intercooler, blow off valve, wastegate, Honda ta, hose, unions, clamps, oil feed line, oil drain line w/ fittings
1400 (can also work out deal with turbo timer, hondata s100, obd0 to obd1 conversion, even ecu if needed)
D series turbo kit complete charge pipes, intercooler, blow off valve, wastegate, Honda ta, hose, unions, clamps, oil feed line, oil drain line w/ fittings
900 (can also work out deal with turbo timer, hondata s100, obd0 to obd1 conversion, even ecu if needed)
OBD0 to OBD1 conversion harness 50
B series valve cover w 2 12 AN bungs 125 firm, tig welded paint stripped on whole cover
d series OBD2 throttle body with sensors 40
OBD0 LS long block mint 400 firm
CX/DX distributor
Excel super stock coil 50
single black gauge pod 20
MSD 6 AL 75
B&M shifter **** 20
D series ultralight flywheel (2) 150
No name dual bend short throw shifter 20
Aftermarket short throw single bend no thread 20
Catch can
AEM cold air intake (civic) 50
Numerous air intakes
Dual gauge pillar; 1 black, 1 gray 25
B series tranny case, inner + outer 80 each side
Kenwood KAC 821 amp used but functions fine
Sony explode XM 504Z amp used but functions fine
Alpine MRP F240 amp, used but functions fine
T4 exhaust flange (2) (brand new) 25 each
T3 exhaust flange (cut off a turbo manifold, use to build a manifold)
D series exhaust manifold flange (cut off a turbo manifold, use to build a manifold)
OBD2 P72 A 70
OBD0 engine mount inserts crx zc 20
Blitz turbo timer 70 bucks
Innovative boost controller 300 firm (this is the system that came out before NLR... works flawlessly) (paid 500 for it used a few years ago)
GSR main studs ARP brand new 75 bucks
Nitrous express NS6500A jets bag full of brand new jets
OEM blow off valve
Kill switch
T3 exhaust flange
Downpipe; 5 bolt brand new 25
38mm wastegate flange 20 brand new
Boost gauage auto meter 2 1/16 (2) 20 each as is
LS cylinder head
OBD0 intake manifold B16
2jz power steering pump
EGR 2jz turbo
oil cooler relocation mount 2jz turbo
2JZ auto transmission jdm,
D series lower timing belt cover (misc just ask)
Exhaust manifold d series/b series just ask
3 bolt engine mount D/b series 3 bolt grey color liquid filled 25.00 each
D series transmission dx no grinds (92-95)
Green Integra doors 95 power doors complete w/glass mirrors just slap on and go
4G63 cylinder head 1st gen dsm cyclone
2nd gen Talon head lights
Cruise control cables and box 2nd gen dsm
Passenger side air bag 2nd gen dsm tsi
Heater controls 2nd gen dsm tsi
Fuel rail 2nd gen dsm tsi
Engine harness 2nd gen dsm tsi
Master cylinder reservoir 2nd gen dsm
Turbo drain line 2nd gen dsm tsi
ECM 2nd gen dsm turbo fwd
Driver side airbag 2nd gen dsm dark grey tsi
Cyclone intake manifold 1st gen dsm (talon/eclipse)
Civic seats 92-95 (blue and grey) fits others 2 diff sets cloth and vinyl
Brand new 14” WV wheel
14” hubcap (acura set of 4) (honda set of 4)
parted out numerous motors/blocks/cars etc
many b series ls/gsr/b16 motors torn apart thru out the years
used rods/pistons/oil pumps water pumps etc
gsr cluster 95
95 get tan interior non leather
misc 01 and 95 teg parts
misc 02-95 hatch/2 doors parts
harley davidson 3 wheel electric golf cart mid 60s (1963 i believe i cant reemember off top of head) works just needs batterys, (they were leaking so tossed them)
started to restore, needs a little tlc but could be really really nice
Cervinnis ram air hood 92-95 civic
Ryobi weed eater (used and runs )
Twist and edge weed eater (used but works fine)
if you dont see something, ask i may even have it
30two 27zero 5one4one is the cell, text only
nasteboyii19943@yahoo.com is email
Old Jul 28, 2011 | 11:14 AM
Bseriescivic5's Avatar
Default Re: fs civic/acura/dsm/2jz stuff, all misc stuff
bump for great guy. Honest seller, and I can vouch for all these parts.
Old Jul 28, 2011 | 01:03 PM
gloria2323's Avatar
the pct ecu is obd2b or obd2a?
Old Jul 29, 2011 | 05:51 AM
nasteboyii's Avatar
ill look tonight and get back with you
Old Jul 29, 2011 | 07:08 AM
lunch time bump
Old Jul 29, 2011 | 11:19 AM
gloria2323's Avatar
ok thanks
Old Jul 30, 2011 | 08:04 AM
nasteboyii's Avatar
ok thanks
i got a pic of it, if u want me to send to ya, i dont remember how to tell obd2a or b
thanks
dan
Old Jul 30, 2011 | 10:01 AM
gloria2323's Avatar
if is a the small ecu pct (ctr) is obd2b 99-00 or if is the big 1 is obd2a 96-98 ecu
Old Jul 30, 2011 | 10:05 AM
gloria2323's Avatar
pmed u
Old Aug 1, 2011 | 07:33 AM
nasteboyii's Avatar
pmed u
you got pm
Old Aug 3, 2011 | 06:37 AM
nasteboyii's Avatar
bump
Old Aug 3, 2011 | 04:10 PM
Chinojdm's Avatar
GLWS man
Old Aug 4, 2011 | 10:33 AM
nasteboyii's Avatar
Originally Posted by Chinojdm
GLWS man
thank you
Old Aug 16, 2011 | 05:48 AM
bump
Old Aug 20, 2011 | 04:04 AM
nasteboyii's Avatar
up
Old Aug 23, 2011 | 04:53 AM
nasteboyii's Avatar
bump
Old Aug 26, 2011 | 05:44 AM
nasteboyii's Avatar
bump
Old Aug 30, 2011 | 04:09 AM
nasteboyii's Avatar
UP
Old Sep 6, 2011 | 08:55 AM
nasteboyii's Avatar
up
Old Sep 10, 2011 | 06:41 AM
nasteboyii's Avatar
BUMP
Old Sep 12, 2011 | 11:24 AM
nasteboyii's Avatar
bump
Old Sep 16, 2011 | 04:35 AM
nasteboyii's Avatar
up
Old Sep 20, 2011 | 04:39 AM
nasteboyii's Avatar
up
Old Sep 23, 2011 | 04:26 AM
nasteboyii's Avatar
up
Old Sep 27, 2011 | 04:33 AM
nasteboyii's Avatar
up
