d16a6
Old Jul 27, 2011 | 08:29 PM
gnxpro24's Avatar
Default d16a6
i recently bought a d16a6 intake manifold to make my daily driver multipoint. the throttle body was missing so I put another one on. the issue is, it has another line coming out of it that the d16a6 throttle body doesnt, but at the same time, is missing the little chamber like thing with a line coming out of it that attaches to the intake manifold
d16a6
non d16a6 throttle body
Old Jul 27, 2011 | 10:21 PM
Canadian_EF's Avatar
Default Re: d16a6
just cap it. you should be fine. mine didn't have it. i think it's dashpot?
Old Jul 27, 2011 | 10:36 PM
gnxpro24's Avatar
Default Re: d16a6
Dashpots are commonly used in dampers and shock absorbers. The hydraulic cylinder in an automobile shock absorber is a dashpot. They are also used on carburetors, where the return of the throttle lever is cushioned right before the throttle fully closes and then is allowed to fully close slowly to reduce emissions of sudden deceleration (compared to deceleration without a dashpot)
so it should be fine capped? wont affect gas mileage?
Old Jul 27, 2011 | 10:45 PM
Default Re: d16a6
yeah basically it makes it so your throttle body doesn't clamp shut so quickly when you let off the throttle abruptly.
it's just for emissions.
if it's a drop in mpg, it will be negligible.
gnxpro24
Jul 27, 2011 09:25 PM
