Map sensor ground?
Old Jul 27, 2011 | 10:35 AM
JacksonD's Avatar
Default Map sensor ground?
So I'm getting a code 3 (map sensor wiring) and I looked at all connections and could not find a short anywhere. I was wondering what type of ground the map sensor uses. Is it a logic or power ground? Or does it matter? And better yet, could I simply re route the map sensor ground from going to the ecu to go straight to a chassis or battery ground?
Old Jul 27, 2011 | 05:53 PM
JacksonD's Avatar
Default Re: Map sensor ground?
Or could I run the map ground to the sensor ground?
Old Jul 27, 2011 | 06:34 PM
JacksonD's Avatar
Does the ecu rely on any information from the grounds at all? After splicing some of the grounds from the harness to the battery I have a code 3 for my map sensor
Old Jul 27, 2011 | 06:53 PM
JacksonD's Avatar
Or do grounds such as sensor logic or power grounds come into the ecu as a ground then all leave ecu from specific grounds? For example the ground wire from the map sensor goes into the ecu a26 as a logic ground then in the ecu gets routed as a power ground and exits as like a27 power ground?
Old Jul 27, 2011 | 07:08 PM
mtflyboy25's Avatar
Chase the wire and find out... Find a wiring diagram use it to see where the ground goes what it connects to and what is going on.
Old Jul 27, 2011 | 09:56 PM
JacksonD's Avatar
Well I saw where on my boomslang harness where the oxygen sensor ground branches out from the map sensor ground was being grounded pre ecu. My wideband is still displaying lean but my new question is : my header u2 bung only implements two runners from the exhaust as opposed to all four runners. Could this be why my wideband displays me on the heavy lean side? (16- "---")
Pryde
Honda Civic (2001 - 2005)
Jun 29, 2014 09:24 PM
Charlie Moua
Apr 18, 2012 07:57 PM
PINKS
Jul 11, 2006 11:57 AM
aXhatch
Jun 24, 2006 04:13 AM
debogsr
Sep 30, 2005 10:33 AM
