b16a1
You need to change a lot..........
- you need a hydro b series tranny
- you need different injectors
- newer alternator
- obdI distributor
- obdI ecu
- newer exhaust manifold
- 4 wire heated o2 sensor
- newer throttle body
Then, you will want to change with fresh parts for your swap
- main seals
- new clutch
- valve cover and tube seals
- plugs
- newer alternator
- obdI distributor
- obdI ecu
- main seals
- new clutch
- plugs
J.D.M_EF9_SI
Jan 25, 2010 05:17 PM
