1st gen CRX/b16 swap...is a/c possible?
Old Oct 2, 2002 | 04:07 PM
Jonathan_ED3's Avatar
Default 1st gen CRX/b16 swap...is a/c possible?
just curious..can't seem to find any info on this.
TIA.
Old Oct 2, 2002 | 04:59 PM
Losrocket_'s Avatar
Default Re: 1st gen CRX/b16 swap...is a/c possible? (hot_EG)
I had a B series in my '87 HB and there was less than 4" between the radiator and header. Its too tight of a fit. Im sure someones done it or could figure out a way to make it work but from my experience with this swap theres no way an a/c comp. would fit in there with a B series.
Old Oct 2, 2002 | 05:57 PM
Brandon Chun's Avatar
Default Re: 1st gen CRX/b16 swap...is a/c possible? (Losrocket'91)
I think the Hasport mounts 2nd generation allow AC for a 1st gen crx. The first version of them didnt
Old Oct 2, 2002 | 06:22 PM
Default Re: 1st gen CRX/b16 swap...is a/c possible? (Brandon Chun)
is there anyway you can confirm this?
Old Oct 2, 2002 | 06:35 PM
CRX7's Avatar
I have place racing mounts which I believe position the engine further forward. I had to get a slimmer a/c fan than stock, but other than that it works great. BTW, I have a 90 CRX DX with B16a and A/C.
Old Oct 2, 2002 | 07:13 PM
Losrocket_'s Avatar
The new billet mounts for the 84-87's do not provide enough clearence for your a/c, because theyre is really no available space to put it. Between the radiator and the firewall there is only so much room and because of the size of the B series motor, there is no way you would be able to keep your a/c. There just isnt any available room for a compressor. You can on 88-91 but in the 84-87 the fit is too tight.
Old Oct 3, 2002 | 05:11 AM
311's Avatar
311
hasport mounts will allow for a/c. Its a tight fit, and I would suggest some heat wrap for the a/c lines,but it will work. A/C owns!
Old Oct 3, 2002 | 07:03 AM
Default Re: 1st gen CRX/b16 swap...is a/c possible? (311)
are you talking about a second gen, or 1st gen CRX? I know it'll fit on a second gen..but I'm asking about a 1st gen.
Old Oct 3, 2002 | 07:12 AM
Hunter's Avatar
yea, i'm not thinkin' it'll work w/ a first gen rex. the b16 is a very very tight fit by itself!
Old Oct 3, 2002 | 07:16 AM
311's Avatar
311
Oh my bad, I am talking about a G2, guess I should read the post first huh?
jokr78
Jan 25, 2005 01:32 PM
illogic65
Sep 16, 2004 05:54 PM
ZCRX
Mar 6, 2002 06:55 PM
GeeSeeR
12
Sep 12, 2001 04:57 PM
