Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
civic 2004 srs no light
Old Jul 26, 2011 | 08:30 AM
eid_05's Avatar
Default civic 2004 srs no light
i have a 2004 civic my srs indacator light does not come on.. help me pls....tnx
Old Jul 26, 2011 | 08:36 AM
GriFFIthS's Avatar
Default Re: civic 2004 srs no light
What do you mean? does it blink when you first turn on the car then go out? if it does thats normal and the system is working just fine.
or does the light not illuminate at all?
Did you buy this 2nd hand? you might wanna have a look at the cluster closely and make sure the previous owner didnt just place tape or something blocking the light.
Old Jul 26, 2011 | 09:17 AM
K24_Y61P's Avatar
If i remember from the car the srs isnt supposed to be on unless there is a problem with the srs system. The fasten seat belt light is on until you fasten your seat belt.
Old Jul 27, 2011 | 12:02 AM
It Wasn't Me's Avatar
As noted.. if the SRS light comes on when you turn the ignition switch on (II) then goes out after you start the car, that's normal.
If the SRS indicator doesn't come on at all, there's a problem. You can check your cluster by putting it through its self-diagnostic.
Gauge Assembly Self-Diagnostic: Link
If the SRS indicator fails to come on, post again. You'll need to do some troubleshooting.
Old Jul 28, 2011 | 05:15 AM
eid_05's Avatar
it does not illuminate at all.. at first i didnt notice it but when i look at gauge when i start the srs light does not come on at all.. it doest blink or anything. help pls.
Old Jul 28, 2011 | 11:07 AM
01_civic's Avatar
i'm betting this car is 2nd hand. I made a DIY on how to cover up the SRS light for people that have blown bags and/or want to block the light because they have aftermarket steering wheels.
There are lots of visual clues to help you figure out if your SRS system has been tampered with. Just look at screws and what not and if they don't look new (i.e have scuffs) then most likely your car has no airbag system.
Old Jul 28, 2011 | 11:09 AM
01_civic's Avatar
BTW in the newer model 7thgens, the SRS light = lite up lil guy with a dot in front of his face (best way i can think of describing it). Unlike the older years with SRS written on the dash.
Old Jul 28, 2011 | 11:49 AM
The problem could be with the gauge assembly itself, or possibly the SRS unit. I'll scribble something together in the next day or two.
Old Jul 28, 2011 | 09:28 PM
eid_05's Avatar
i asked my dealer if my bags are already used but they said that my bags has not deployed yet.
Old Jul 29, 2011 | 12:28 AM
Try swapping gauge clusters. Used ones are all over the internet. Get one that matches your car.
If the problem persists after swapping gauge clusters, post again.
Bleakened
Dec 12, 2014 12:29 PM
shawnlee250
10
Jan 11, 2012 12:39 AM
skaternak
Aug 6, 2008 08:31 PM
spooncivic1
Mar 11, 2007 04:10 PM
