02 rsx failed smog, HELP!!!
Old Jul 26, 2011 | 06:56 AM
whitehf's Avatar
Default 02 rsx failed smog, HELP!!!
the car ran fine, it passed everything but the smog tech said it failed due to the computer being reset. I had a CEL for due to a skipped chain about a month ago. I reset cleared out the CEL with my obd2 reader and the CEL never came on. The tech said somthing about driving the car for 100 miles non stop for the computer to start reading all the temps again. Has anyone ever had this problem?
Old Jul 26, 2011 | 08:03 AM
drzxc1usive's Avatar
Default Re: 02 rsx failed smog, HELP!!!
go for a long drive right before you go test it...
Old Jul 26, 2011 | 08:04 AM
BTW hes right
Old Jul 26, 2011 | 08:43 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I'm so glad I have no emissions testing....
Old Jul 30, 2011 | 07:29 AM
whitehf's Avatar
so i ran the car for 120 miles non stop and it still didnt pass smog....its also my daily driver..smog test still said fail on mil/check engine light..is it because i have a bad ecu? its a 2002 base auto rsx...can i use a 05 civic si ecu or are the plugs different?
Old Jul 31, 2011 | 09:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
There are monitors in the PCM that check for certain parameters. If any sensor/condition exceeds those parameters, the monitors will double and triple check to make sure there is an actual problem. Once an actual problem is confirmed, the check engine light will come on. When ever you erase a code you reset the monitors. Part of the smog test procedure is to ensure the monitors are set. This way people cannot simply erase the MIL before getting a smog check. They will have to actually repair the problem rather than simply erasing the code. All OBD 2 compliant vehicles have monitors.
team_ibR
May 27, 2010 02:53 PM
Sinology
Oct 20, 2009 03:57 PM
Unlimitationz
May 6, 2005 03:20 PM
Unlimitationz
Apr 30, 2005 09:37 PM
undertheradar
Oct 18, 2004 02:45 PM
