crx sohc zc swap low idle 550rpm???
88 crx dx
swapped sohc zc
converted to mpfi
pm6 ecu(canada)
all new gaskets on intake manifold
no clear vacuum leaks double checked all lines
short ram intake
runs good!
the car idles consistently around 550-650 rpm, but stock canada pm6 is suppose to be 800???
ive attempted multiple times to adjust the idle via honda manual directions but cant get it to go up? the EACV is supposedly properly working does everything else well! it drops once its warm? any ideas peeps
swapped sohc zc
converted to mpfi
pm6 ecu(canada)
short ram intake
runs good!
DumpdEJ6
12
Aug 4, 2013 05:16 PM
b18hondahb
16
Oct 13, 2006 05:40 PM
