Suspension & Brakes Theory, alignment, spring rates....
What do you think of these alignment specs?
Old Jul 25, 2011 | 05:58 PM
preludeNApower's Avatar
Default What do you think of these alignment specs?
So im setting my car up for street/autocross and wanted to hear some opinions on the specs I plan to run The car handles pretty neutral right now. I have Eibach sport springs, KYB gr2 struts, f&r strut braces and f&r LCA braces.
Right now I believe my settings are ...
Front
Camber- -1
toe- 0
rear
camber- -1.5
toe 0
and I was planning to put it at...
F
Camber -1.5
toe -.25
R
camber -.75
toe 0
Old Jul 25, 2011 | 07:01 PM
racebum's Avatar
Default Re: What do you think of these alignment specs?
toe is all wrong. set the front to -.05 out on each side and the rear .08 in on each side. that car will be nervous at speed with those settings
Old Jul 25, 2011 | 09:20 PM
civexspeedy's Avatar
I'll run anywhere from -.04 to -.06 in the front and somewhere around +.14 to +.16 in the rear.
The car is a bit twitchy, esp with the suspension setup. I don't let ANYONE drive my car on the street. And I don't drive it on the street much anyways since it's mainly used for autox. I have a much more comfortable DD. But, it does very well at autox events and I personally like a fairly loose car.
I'd start out around with what racebum said and go from there.
Old Jul 26, 2011 | 02:52 AM
Libertariat's Avatar
Ek Forever y0!
These are the settings I run, the car handles like a dream.
Old Jul 27, 2011 | 06:14 PM
thanks for the input,
Also, I am running a 215 40 16 marangoni zeta lina
Old Jul 28, 2011 | 08:14 AM
Mr. Spade's Avatar
Never heard of those tires but if they are just regular street tires then your camber as suggested is good but I say .1 toe rear and .05 toe front.
Then again I have crappherson struts with shitty tie rod bushings that like to toe in so I run a little out
Old Jul 28, 2011 | 06:42 PM
Correct me if I am wrong but wont these toe specs both front and rear create more understeer?
Old Aug 5, 2011 | 09:04 PM
NIKE SB'd's Avatar
.25 out in the front and zero toe in the rear is actually going to create more oversteer and 1/4" out in the front is way excessive, you'll just be destroying tires. I run 1/16" out front and zero rear on my track car and really wouldn't recommend zero toe rear for the street, it's amazing how much a little toe change in the back does for the car's rotation. For a daily driver I'd stay around 1/32" out front, 1/16" in rear.
Old Aug 6, 2011 | 05:08 PM
FlewByU352's Avatar
I hate 0 toe in the rear, at higher speeds it felt unstable to me.
Old Aug 8, 2011 | 06:23 PM
Ek Forever y0!
Which is why it should be in a hair. Probably .05 total toe in at the most.
Jon777
Suspension & Brakes
May 10, 2011 10:23 AM
pwebb0207
Suspension & Brakes
Apr 5, 2011 06:04 PM
Francesco
Honda S2000
32
Jan 30, 2006 08:33 PM
nichols_si
Oct 2, 2003 12:03 PM
Reid
Jul 5, 2002 01:24 PM
