FS: NEW K Swap, Dart B Series Block, LS Turbo Kit, Spoon, Turbonetics
FS: K24 TSX longblock with 5000 Documented miles and all the Paper Work- $2500
Brand new K20 Transmission with LSD Installed by Kingmotorsports. 0 miles never used- $2500 with Brand new K Series ACT Clutch and Flywheel
Hard Race DC2 Front Torque mounts- $50
96 Spec ITR 15/16 booster and Master Cylinder- $100
Spoon Ep3 Engine Trq Mount - $200
******The Following Came out of a Friends DA Race Integra, I don't have all the Specs but PM me with any questions on the following, you can also email me for faster response at omgrhd@gmail.com*******
B Series Dart Block with Eagle Rotating assembly, ITR oil pump with prodrive gears, ITR Water pump, Arias Pistons, ACL bearings, Moroso 5 qt Oil Pan- $2500
LS Head with valve job and springs/retainers and ARP head studs- 350
LS Cams with Adjustable Cam Gears- $75
LS Cable Transmission with Kazz LSD (3rd gear synchro might be on its way out) $450
Aluminum Radiator- $100
DA B series motor mounts- $100
Golden Eagle Sandwhich Adapter - $50
ATi Super Damper B series Crank Pulley- $200
Edelbrock Victor x manifold for LS Head with 650 ccInjectors/TB/FPR - $300
Omni Drag Coilovers Front and Rear - $300
Vibrant Timing belt Stabilizer for b series-100
Driveshop axles and hubs rated for 600 hp- $500 plus stock front knucles in exchange for the knuckles with the special hubs.
Full Turbo Kit for B series, piping is for DA Integra- 800
Sparco bucket seat- 100
DA Integra Traction Bar- 200
ACT 6 Puck Clutch with Light weight flywheel- $200
DA Integra Shell, clean CT Title, Stripped body is stright- $750, also willing to part out body.
Thanks for looking!
Thanks for looking!
AllMotorDan
Jan 14, 2012 11:57 PM
underrated99si
Aug 5, 2003 12:09 PM
