WA FS: 1993 Integra ls w/ built 1.8 GSR Turbo,itr 5lug,CF out!
1993 Acura Integra GSR Turbo! 5lug - $8000 (auburn)
Selling my 1993 Acura Integra Turbo with a 2000 Gsr motor,gsr hydro tranny swap, Fully Built motor for boost, 5k on motor, 2k on turbo system, Makes 430hp 277tq. on 18psi pump gas, runs smooth, pull Hard, doesnt smoke,Have receipts for everything! Selling to buy Friends bmw...ask for Kris 253-797-0877 Asking $8000 for everything, Or will sell for $3800 with a stock Ls motor swap,stock seats, Or will sell for $2800 rolling chassie, will remove roll cage upon request of buyer......NO TRADES, NO LOWBALLERS,NO JOY RIDES.....quick low down
Exterior/suspension- Type R 5lug suspension,brakes and wheel bearings are good, ITR usdm wheels on kumho tires 205-50-15 with 80%tread, arp extended studs, extended lug nuts, skunk 2 camber kit front and rear, kyb struts, skunk 2 coils 10k rear, 6k front, explicit speed performance traction bars, jdp carbon fiber lip, vis carbon fiber hood, vis cf fenders,vis cf rear hatch
Interior/shift lever-S2k Seats, rear gsr leather,art morrison 6pt. cage, Type R JDM guage cluster, PLX 300 wideband, autometer pyro guage, autometer boost guage, acautotechnics water and oil guages, Converted cable clutch to full hydro pedal, Type R shifter, Type R shift ****, Type R shift linkages, poly shif linkages bushings
Engine/fuel- 2000 Gsr longblock, eagle rods,arp studs, cp pistions 81.5 GE block guard, GE oil squirters block off, oem bearings, type R oil pump,copper head gasket,
2000 Gsr head port polish, manely valves, crower dual springs and titanium retainers, Type R cams, Toda cam gears ,kevlar timing belt, Victor X polished intake mani, hondata gasket, polished valve cover, GE fuel rail, 1000cc saturated injectors, injector dynamics, areomotive fuel filter, areomotive FPR, New Distributer, NGK plugs, NGK wires,
Turbo System--Borg Warner S362ett turbo rated 650hp, SLS- t3 Topmount mani with dual 38 wastegates, 2 tial mvs 38mm wastegates, tial 50mm BOV, full race backdoor FMIC, 2.5" aluminum charge piping, p28 ecu with hondata s300, boot by gear mac solonid, 3" downpipe, 3' electric cut out from qtp
check out youtube videos, search kmaz369
