denso plugs and nitrous
Old Oct 2, 2002 | 03:23 PM
stupidfast's Avatar
Default denso plugs and nitrous
what do you guys think of the denso plugs in a nitrous application?? do they work and do they last.. or should i just stick with ngk?
Old Oct 2, 2002 | 03:28 PM
It's Blue's Avatar
New User
Default Re: denso plugs and nitrous (stupidfast69)
Stay with the NGK coppers. You know better than that.
Old Oct 2, 2002 | 03:35 PM
stupidfast's Avatar
Default Re: denso plugs and nitrous (It's Blue)
did you see my sig, 12.7 baby,and i just ran a 12.8 on sunday with a 75 shot..
[Modified by stupidfast69, 12:36 AM 10/3/2002]
Old Oct 2, 2002 | 07:33 PM
UNVMYR's Avatar
I burnt a set with one spray,I dont reccomend them!
Old Oct 2, 2002 | 07:49 PM
It's Blue's Avatar
New User
Hmm. that's cool you ran a 12.7 at Firebird with a 100 shot of nitrous, but what does that have to do with understanding that with the Denso plugs are not compatible with nitrous?? Reason is because the Denso's retain heat "which is bad", could cause detonation thus causing a misfire.The copper plugs "mainly two stage cooler ones" do not retain that heat, therefore are a better choice for running nitrous. Stop listening to Paul and the other people in Boise that want you to waste $60.00 of your hard earned money, just to be able to say that your new spark plugs from Denso are made from the hardest metal known to man and came from a metor that hit earth however many millon years ago. You know that we cannot run anything but copper plugs in a nitrous motor, unless you want to lose your motor. Best of luck Anthony
Old Oct 3, 2002 | 05:29 PM
stupidfast's Avatar
actually paul wants me to run ngk and i dont listen to what other people tell me..and you dont need to be a ***** about the fact that i mentioned i ran 12.7 i just thought you would be stoked for me like i was when you ran 12.8. i quess i was wrong..thanks for the advice.
umair
Mar 1, 2009 03:17 PM
hondaeg8
Sep 26, 2004 11:46 PM
blackem
Mar 8, 2004 11:12 PM
Goldfingiz
Jun 5, 2003 11:25 AM
