Getting Code 43 in obd1 b20b swap
Old Jul 25, 2011 | 09:59 AM
93grayeg's Avatar
Icon2 Getting Code 43 in obd1 b20b swap
Im getting code 43 in my 89 si with a b20b swap, Where should I start? The car runs really rich, has a slight hesitation at partial throttle... I unplugged the o2 sensor and the miss didnt go away...any ideas where to start? Thanks guys
Old Jul 25, 2011 | 12:22 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Getting Code 43 in obd1 b20b swap
Do you have an aftermarket fuel regulator? Those are notorious for causing code 43s if not setup properly.
Usually the o2 is the problem for code 43, but you need to change the O2. Running with the O2 unplugged will just make matters worse.
A bad O2 may not always throw a code and will make you run rich. The rich problem may cause misses/hesitations.
If you still get the code at this point, then it may also be a weak ignition system.... cap, rotor, wires, plugs, coil.
Old Jul 25, 2011 | 11:59 PM
93grayeg's Avatar
I just put on a new distributer , next m going to get a 02 sensor , my car has a 4 wire o2. What year car does the obd1 4 wire 02 sensor come from? Car has a stock fuel pressure regulator
Old Jul 26, 2011 | 12:00 AM
93grayeg's Avatar
Also it seems to throw the code more at night time when the air is cooler if that makes any sense
Old Jul 26, 2011 | 05:29 PM
93grayeg's Avatar
anyone?
Old Jul 28, 2011 | 07:40 PM
93grayeg's Avatar
need help guys
Old Jul 29, 2011 | 07:30 AM
4drEF's Avatar
Keyboard Humorist
You get a new O2 yet?
Old Jul 29, 2011 | 08:26 AM
93grayeg's Avatar
I need to know what 02 sensor to get? All I know is the one I have is a obd1 4 wire o2 sensor. What is this o2 sensor from?
Old Jul 29, 2011 | 12:52 PM
4drEF's Avatar
Keyboard Humorist
Not sure what ECU you have, but ff you are in any sort of doubt, you can get an O2 for the stock engine for your ECU.
But honestly any will work 4 wire Honda/Acura O2 will work. The connector may be a little different, but they all work the same.
Bosch make universal ones that you have to do simple wiring for - those have always worked fine for me.
Old Jul 29, 2011 | 09:50 PM
93grayeg's Avatar
I plan to go tommorow and get one, maybe I should just take my old one in with me. Im running a obd1 ls ecu , Would a obd1 integra o2 sensor be the same thing? I also went to honda and ordered a new fuel filter
Old Jul 30, 2011 | 11:35 AM
93grayeg's Avatar
I put a brand new oem honda fuel filter in today and it seemed to make a little difference but not fix the issue , Im going to get a new bosch 02 sensor today as well
wfking
Engine Management and Tuning
Apr 3, 2018 12:22 PM
crx_si-r
Feb 17, 2010 05:16 PM
JD95hatch
May 18, 2006 02:51 PM
EFz6er
Nov 1, 2005 09:39 AM
DSRxCandyh2bEG
May 24, 2003 08:23 PM
