Suspension & Brakes Theory, alignment, spring rates....
proper tightening for koni struts
Old Jul 25, 2011 | 09:22 AM
gofastgokart99's Avatar
They call me the part of a womans vagina that causes pleasure.
Default proper tightening for koni struts
I searched, nothing answered my question.
I just installed a new Knoi/GC set up on my integra along with ASR subframe brace/24mm sway bar, Function & Form LCAs, and a couple other new OEM parts for the front.
My question is this: for the top hats, are they supposed to be tightened down to the base of the threads on the strut? I am talking about where the styrut come through the small hole in the top hat and locks with two 19mm
(I think) nuts on top. I have them snug right now but did not want to go crazy on them with out knowing how to properly tighten them.
any input is appreciated.
-Garrett
Old Jul 25, 2011 | 10:18 AM
Tyson's Avatar
Default Re: proper tightening for koni struts
you want to get them as high as possible by threading the nuts all the way down. otherwise the piston internals will sit lower and more chance of bottoming out internally. and you dont want any slack between the bushings.
Old Jul 25, 2011 | 03:23 PM
so tighten the lower nut as much as possible without over tightening?
Speed Weed
15
Feb 26, 2016 06:47 PM
whiteteggy44
Oct 4, 2011 06:11 AM
93_hatch
Suspension & Brakes
Mar 25, 2006 08:00 AM
Modify
Aug 15, 2005 06:31 PM
Demon_Dub
Apr 5, 2004 02:26 PM
