sitting on side of road!!
Old Jul 25, 2011 | 05:59 AM
rydinsolo's Avatar
Default sitting on side of road!!
ok well i was driving this morning and i stopped at a gas station to get a soda, when i came out my car did not start. now i have a few other threads for mnultiple problems with this car. it has a dpfi to mpfi swap and the wiring is ****ed up. it is throwing codes 20/19 and it throws 10 every couple of times, the car was running but missing and im almost home, but it starts, but when you apply gas, like nothing it just sounds likt there is a loping cam in it..
can anyone help please like asap
Old Jul 25, 2011 | 06:00 AM
rydinsolo's Avatar
Default Re: sitting on side of road!!
and btw i just looked the load detector wire is cut right after the plug, but it has been since i got the car...
Old Jul 25, 2011 | 06:36 AM
rydinsolo's Avatar
well got it home, guess i will go form here. i am not quite understanding this, i have done what the mpfi conversion said to do but the car is running like shiieetttt
Old Jul 25, 2011 | 06:39 AM
4drEF's Avatar
Keyboard Humorist
No way to tell what's wrong other than the obvious which you already stated.
Fix your wiring.
Old Jul 25, 2011 | 06:48 AM
rydinsolo's Avatar
yeah im talking to someone local who builds harnesses from scratch. having him look at it tomaro
Old Jul 25, 2011 | 06:55 AM
cetcivic's Avatar
no one wants to hear the truth
I'm almost sure its the rear view mirror
Just kick it clear through the windshield
And I bet it'll start right up like viagra does to a snoozin ol man
Old Jul 25, 2011 | 08:06 AM
rydinsolo's Avatar
LMAO... i duno man who ever did this conversion is a dam idiot, i mean i dont know if they did all this because they used a PM7 ECU but jesus like its a xmas tree of wires..
does anyone know do you HAVE to use a SI distributor for the mpfi swap??
Old Jul 25, 2011 | 08:10 AM
4drEF's Avatar
Keyboard Humorist
YES. Or one from an HF.
Sensors in the DPFI distributor are only capable of running 2 fuel injectors.
Old Jul 25, 2011 | 08:22 AM
rydinsolo's Avatar
hmm well maybe that is my problem, i am new to the honda game and i do not know how to tell which one i have. like i said i know i have all the wires hooked up, i went over it at least 3 times. but the dis was alrede in there from previous owner swap.
can you plleeasee tell me how to identify which dis i have?
Old Jul 25, 2011 | 08:52 AM
dephtone's Avatar
Look on the ear of the distributor, one of them will be stamped with td-01 (DPFI Distributor) or TD-02 (MPFI Distributor this is the one you need). That's saying the car still has a D series in it, and is OBD-0
Code 19 = Auto Tranny Lock up Solenoid, which will throw when you have an auto ECU hooked up to a 5 speed car.
Code 20 = ELD which is the plug you said is cut.
Old Jul 26, 2011 | 02:25 PM
rydinsolo's Avatar
mine is stamped this-
td-18u
9x18
so which distributor do i have??
Old Jul 26, 2011 | 03:05 PM
rydinsolo's Avatar
well i am getting differnt readings when googling the TD-18u number
HONDA Application
TD01U Civic 88-91 (1.5L)
TD02U & TD18U Civic 88-91 Si (1.6L) & CRX 88-91 Si (1.6L)[/B]
TD22U Civic 88-91 JDM B16A (Japanese Spec.)
TD41U Civic 92-95 (1.5L)
TD42U Civic 92-95 Si (1.6L)
TD43U Civic ZC Engine (2nd Gen. ZC)
TD80U Civic 96-98 (1.6L Non-VTEC)
TD63U & TD73U Civic 99-00 Si DOHC VTEC (1.6L)
TD31U & TD34U Accord 90-91
TD52U Accord 92-93
TD58U Accord 94-95 (2.2L)
TD76U Accord 96-97 (2.2L)
TD89U Accord & Prelude Type S DOHC VTEC H22A
TD77U Prelude 97-02 VTEC
TD59U Prelude 92-96 non-VTEC (2.2L)
TD60U Prelude 92-96 JDM VTEC (2.2L Internal Coil)
TD61U Prelude 92-96 VTEC (2.2L) & 92-96 non-VTEC (2.3L External Coil)
TD97U CRV 99 & up (2.0L)
i guess i have the right one for the dpfi to mpfi swap
Old Jul 26, 2011 | 06:06 PM
rydinsolo's Avatar
ok so can someone please explain. i bought this hatch with a dpfi to mpfi conversion, has a TD-18u distributor, has a PM7 ECU which is a dohc ZC JDM ecu. the car will run on the PM7 ecu, i put a PM5 and the car will not start..im so loossstt
Old Jul 26, 2011 | 08:00 PM
uberEFtuner's Avatar
Don't put in a pm5 its for 2 fuel injectors, also its for high impedance injectors.
If you don't know what your doing stop!!!! Read until you know what your doing.
Old Jul 27, 2011 | 09:01 AM
rpmraper's Avatar
im assuming you are obd1 dseries? if so just run a p28
Old Jul 27, 2011 | 09:04 AM
rpmraper's Avatar
also i believe you need the distributor off a 92-95 civic DX and if you dont already have them, get a distributor, and ecu jumper from rywire..also did you use the 4 wire o2 sensor, just something to think about..
Old Jul 27, 2011 | 09:05 AM
rpmraper's Avatar
obdo has one wire o2, obd1 has 4 wire.
Old Jul 27, 2011 | 09:08 AM
rpmraper's Avatar
sorry for so many posts, but your distributor is obdo 88-91 honda civic 1.6 distributor..just so you know.. so its prob the d16a6 distributor is my guess, hope i helped.
Old Jul 27, 2011 | 10:05 AM
rydinsolo's Avatar
Yes, i ended up figuring out what dis i had. I am OBDO running on a PM7 jdm zc ecu. It was in the
Car when i bought it. All that is done it is a dx ef hatch. They attempted a mpfi swap and messed it up
Old Jul 27, 2011 | 04:15 PM
vtecn8ive's Avatar
never seen a distributor abbreviated to "dis". Say dizzy next time.
Old Jul 27, 2011 | 04:52 PM
rydinsolo's Avatar
my bad, I have not seen a post anywhere stating what abriveations to use for which things...........
Old Jul 27, 2011 | 04:53 PM
rydinsolo's Avatar
so can anyone explain how my car is running off of a Pm7?? its JDM ECU, its for a DOHC which my motor is not a jdm swap, nor is mine dohc
Old Jul 27, 2011 | 05:24 PM
4drEF's Avatar
Keyboard Humorist
The ECU doesn't care how many cams you have.
Old Jul 27, 2011 | 07:08 PM
rydinsolo's Avatar
oh, ok i was told that the jdm dohc zc motor uses a second cam sensor, so running that ecu on a songle cam would cause it to run like **** woudl it then??
Old Jul 27, 2011 | 08:26 PM
JDpower's Avatar
The distributor is different on a dohc zc because it has the cam sensor not in the dizzy (dis) but the ecu reads it all the same as it would a d16a6 si. The pm7 is close enough to the pm6 may just run a lil rich(and have a higher redline) but way better than running a pm5 (which is missing that cam sensor and 2 injectors). I ran my dohc zc off a pm6 and it ran lean (for smog) and did better on gas till I could pick up a PG7(pm7).
