Sleeved B18C1 Turbo Block, Skunk2, ASR, SSR Wheels, Wilwood Brakes, Greddy! and MORE!
EVERYTHING IS FOR SALE!! I ALSO HAVE BASICALLY ALMOST EVERY BOX/RECEIPT for everything i purchased, along with Dyno sheet.
My Car cruising around on my SSR Type C Wheels
MY OFFICIAL DYNO SHEET
<---- conservative tune, but most definitely can push more
Engine:
Original B18C1, NEVER BLOWN before, was built for Boost.
Block Sleeved by RS Machines
83mm Bore
Forged Arias 10.0:1 Pistons
Forged Eagle Rods
OEM Oil Pan <------ Sell together for $1,600.
or will sell sleeved block alone with no pistons, rods for $800
Original GSR head - Original Ports <---- Enitre head SOLDD
Portflow Valve Springs
Portflow Retainers
Skunk2 Stage 2 Cams
Evolution Time N Lock Cam Gears
REVHARD Intake Manifold <---SOLD
Spoolin Performance Oil Catch Can hooked up to Custom Vented Valve Cover <---$200
Original GSR Transmission with matching VINS <----SOLD
Greddy Turbo COMPLETE Kit which includes the following <----- SOLD
Garrett GT3076R Turbo
Spoolin Performance Ram Horn
Tial 38mm Wastegate
Spoolin Performance Intercooler - 24x9x3 - Sprayed Black
Spoolin Performance Charge Piping
Synapse Synchronic blow off valve
Oil and Coolant Lines
Greddy Profec B Electronic Boost Controller
Spoon Sports 70mm Tapered Throttle Body - $500obo
Injector Dynamic 1000cc Saturated Fuel Injectors <--- SOLD (7-27-11)
Walbro 255 LPH High Pressure In Tank Fuel Pump <---- SOLD
3 Inch Magnaflo Exhaust with 3 Inch Straight Thru Vibrant Performance Muffler (PRETTY QUIET!) <---- SOLD
JVT Half Radiator <-----SOLD
MSD Coil SS
MSD 6A <----- Together for $200
Crome Chipped OBD1 P72 ECU <---- $150
RZ Spec Clutch <----- SOLD
Fastline Stainless Steel Braided Clutch Line <---- SOLD
AEM Meth/Water Injection <----- SOLD
Exterior:
100% REAL OEM Acura Integra Type R Front Lip (not that fake ebay ****) <---- SOLD
5000k HIDs <------ SOLD
S2000 Antenna <---- SOLD
JDM Window Visors <---- SOLD
Suspension / Brakes / Wheels / Tires:
SSR Type C (WITH SSR CENTER CAPS) - Gunmetal with Polish Lip - 16"x7 +42 Offset (4X100) with Falken FK452 - 225/45/16 tired. 30% tread life left <----- $900 FIRM
OMNIPOWER FULL COILOVERS <----- SOLD
ASR Rear Subframe Brace <---- SOLD
Type R Rear Sway Bar with Type R LCA and bolts<----- SOLD
Ingalls Camber Kit <---- SOLD
12.2 Inch Slotted and Drilled Front Rotors With Wilwood 4 Piston Calipers <--- SOLDD
Fastbrakes 11 inch rear rotors <---- $350obo
Neuspeed 4 point Front Strut Bar <--- $150
DRIVE Brake Master Cylinder Brace <---- $75
Interior:
Autometer Cobalt Gauges - OIL PRESSURE, WATER TEMPERATURE, BOOST
PLX Air Fuel Ratio Gauge <-------- ALL SOLD
Pioneer DEH5200 Headunit <----- SOLD
Fastline Road Race Shifter <----- SOLD
Circuit Hero Shift **** <---- SOLD
Text me or PM me with an offer or if you want to buy something. I'm willing to work with some things but not all.
MY NUMBER (206) 518 - Seven Nine Seven Zero
<---- conservative tune, but most definitely can push moreEngine:
83mm Bore
Forged Eagle Rods
Portflow Retainers
Skunk2 Stage 2 Cams
Tial 38mm Wastegate
MSD Coil SS
Exterior:
Interior:
Oh my bad! lol i meant to write that all of the autometer gauges including the air fuel ratio gauge were 250 or best offer. I'm willing to work with some items in terms of prices.
nice, B18C1 turbo
are what Wilwood brakes are good for integra?
you had to change the brain brake cylinder or meter?
Mr. Wonderful
Feb 14, 2008 10:06 PM
ozzyman
80
Jan 13, 2004 09:16 AM
