Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Best tires
Old Jul 24, 2011 | 08:24 PM
95TeggyB20Vtec's Avatar
Default Best tires
Looking for a good road racing tire not too pricey
Old Jul 24, 2011 | 08:39 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Best tires
Click on the search this forum area and type "tires"
Tons of information.
Old Jul 24, 2011 | 11:14 PM
rice_classic's Avatar
Does not compute.
Old Jul 25, 2011 | 01:43 AM
dees26's Avatar
Toyo RA1 or R888 are great R-comp tires..
Old Jul 25, 2011 | 06:07 PM
soloteg's Avatar
Kumho ecsta asx's are totally sticky broheim.
Old Jul 25, 2011 | 06:27 PM
CivicSiRacer's Avatar
circular ones, don't let anyone tell you triangular ones are faster
Old Jul 25, 2011 | 06:29 PM
92integraVTECgsr's Avatar
Nitto NT-01. Best bang for the buck IMO. NT01 and RA1 are the same compound, just different tread pattern and different name.
Old Jul 25, 2011 | 06:35 PM
The Destroyer's Avatar
Asx stick out well, not too extreme.
Old Jul 26, 2011 | 06:11 PM
lwnslw's Avatar
Old Jul 30, 2011 | 09:17 AM
EG Civic Si's Avatar
The problem with the NT01 os that they are assymetrical...
You can almost double the use using the RA1 by switching side and side
Old Jul 30, 2011 | 09:20 AM
Egezzy's Avatar
Spongebrad Squarepants
Originally Posted by The Destroyer
*** stick out well, not too extreme.
not too extreme. perfect if you ask me.
Old Jul 30, 2011 | 09:26 AM
bks84's Avatar
Loved
In another thread they mention the Kumho SX. Thats what I will be purchasing as soon as I find a cheap set of track wheels.
Old Jul 30, 2011 | 09:37 AM
XS, dont buy the wrong ones.
Old Aug 2, 2011 | 07:17 PM
jdmdohcek98's Avatar
kumho xs are good for the price, I paid $108 a tire through tirerack plus a $50 gift card. BTW best and not too pricey don't go together.
Old Aug 2, 2011 | 09:08 PM
Scott.'s Avatar
no love for the dunlop star spec's?!
Old Aug 2, 2011 | 09:23 PM
apwhat's Avatar
fail post
Old Aug 3, 2011 | 03:57 AM
VTECIntegra9's Avatar
Originally Posted by apwhat
fail post
+10
(damnit I just bumpped it didn't I)
People... if you're going to post up something that is clearly already available on the forums... at least put some effort into it!
Old Aug 3, 2011 | 07:31 AM
bks84's Avatar
Loved
Thanks for straigtening that out, a long day causes typos
Old Aug 3, 2011 | 12:21 PM
soloteg's Avatar
That what I have, there were a no brainer with the 80$ rebate.
Old Aug 3, 2011 | 12:50 PM
Egezzy's Avatar
wanlis ftw!
Old Aug 3, 2011 | 01:30 PM
JHall250's Avatar
Depends on size, 3 good "bang for the buck" street/track tires in 15" are Falken Azenis, Kumho XS (205/50R15) and Hankook R-S3 (225/45R15). Then there are the DOT comp tires mentioned above: Toyo RA-1, Nitto NT-01, Toyo R1R which are all very similar. DO NOT under any circumstances buy Toyo R888, those tires suck so bad that Toyo had to start making the RA-1 again because Spec Miata and Honda Challenge were so pissed about how much the R888 sucked.
Old Aug 3, 2011 | 01:35 PM
Egezzy's Avatar
that street tire(140+) recommendation is off pretty bad.
140+:
rs3.
re11.
star spec.
r1r.
ad08. putting this in because of what i have seen. i don't know anyone personally but figured i would toss it out there.
615k.
r comps:
given the question, we might as well not go there.
Old Aug 3, 2011 | 01:52 PM
JHall250's Avatar
140+:
rs3.
re11.
star spec.
r1r.
615k.
r comps:
"Looking for a good road racing tire not too pricey" Original post
I said street/track tire, meaning double duty. Anything with a treadwear rating higher than 140-180 will get sheered off on the track. All the tires I have mentioned are the closest you can get to track tire without breaking the bank. So what are you talking about?
Old Aug 4, 2011 | 07:42 AM
Egezzy's Avatar
you must be confused on "road racing" first off. second off you mentioned the r1r with the ra1 and the nt01..hmmmm.
anyways you mentioned the 615 which i am assuming you are talking about the new k model. well you can get that at discount tire for 130/per tire in a 205/50/15. you can get the re11 from tire rack for 138/per tire in the same size. the xs has a lower treadwear rating than the star spec but i see the star spec used more often on the track than i do the xs. the price point on those through tire rack are like 115/per star spec and 105/per xs in the 205 size. the rs3 is a very good tire for the money but the size might be too much for some and also the availability. i think their release date is the end of this month, so that makes what 2 months without any tires available. guess the tires "bang for their buck" isn't good if you can't purchase them. the r1r can be found in a 205/50/15 for 125/ea. so you are looking at a maximum difference of around 30 dollars per tire. that would equal 120 dollars for a set, if that is breaking the bank then work some ot.
Old Aug 4, 2011 | 07:46 AM
4cylfiend's Avatar
BRAP!!!
