b16 tranny with broken case
Old Jul 24, 2011 | 08:21 PM
ever'sneighborhood's Avatar
Default b16 tranny with broken case
so i broke the case of my b16 cable tranny today on the freeway, so i was wondering if i could buy an ls cable tranny and and use the case from that tranny on my b16 tranny?
Old Jul 24, 2011 | 10:21 PM
rd91sib18c5r's Avatar
Default Re: b16 tranny with broken case
Hydro or cable?
Old Jul 24, 2011 | 10:47 PM
el crapitan's Avatar
All b series cable are same.
All b series hydro are same
Old Jul 24, 2011 | 11:23 PM
gnxpro24's Avatar
you can even use any hydro gears in a 92-93 (not 90-91) cable transmission housing
Old Jul 25, 2011 | 12:59 AM
No they aren't.
Old Jul 25, 2011 | 01:07 AM
slomofo's Avatar
GDD Member
Originally Posted by rd91sib18c5r
No they aren't.
On the casings.... not all are the same, but the ones you're likely to come acrossed will undoubtedly all be the interchangeable.
Gears are different though.
Old Jul 25, 2011 | 06:30 AM
my b16 tranny is cable and im planning on buying ls tranny cable, so would it work?
Old Jul 25, 2011 | 09:26 AM
slomofo's Avatar
GDD Member
Yes
Old Jul 25, 2011 | 08:00 PM
alright thanks to everyone
Old Jul 25, 2011 | 10:36 PM
ERKK's Avatar
how hard is it to switch cases
Old Jul 25, 2011 | 10:51 PM
gnxpro24's Avatar
you have to make sure you have the right year transmission. if your b16 transmission is a 90-91 (S1 J1 A1) then you have to get another 90-91 transmission. if your transmission is a ys1 (92-93) then you can swap between any 92+ b series transmission. you cant put 90-91 guts in a 92+ or vise versa
Old Jul 25, 2011 | 11:12 PM
ohh alright got it. and also i was wondering you guys think jb weld would work? like to seal the cracks?
Old Jul 25, 2011 | 11:22 PM
EatMyVTEC :]'s Avatar
It will still leak after a while. you will be better of switching cases
Old Jul 25, 2011 | 11:28 PM
alright alright cause money is a problem right now but im sure i can find a case somewhere for a good price
Old Jul 26, 2011 | 02:42 AM
dsmchad's Avatar
My question is what caused the case to break to begin with?
Old Jul 26, 2011 | 07:13 AM
it broke on the freeway i hit a bump and it all went bad from there
Old Jul 26, 2011 | 08:02 AM
ERKK's Avatar
Im in the same boat... how hard is it to change cases
Old Jul 26, 2011 | 08:37 AM
dsmchad's Avatar
Im a manual trans expert, i dont understand how you can break the case by hitting a bump, unless your saying it hit the road and split it open, then that woud make sense.
Its really not a job for an average backyard wrench to change internals and cases on a trans, though hondas are fairly simple. just pay very close attention. If youve never been inside of a trans before.. good luck. I do alot on the side out of my garage, but cali is a little too far from ohio lol
PM me if you need any advice once you get that far with it.
Old Jul 26, 2011 | 08:54 AM
MemphisCRXfan's Avatar
A bad angle on a cv-axle will do it. Is your car lowered (slammed)?
Old Jul 26, 2011 | 09:10 AM
B16-CRX's Avatar
I have an extra case... but the side that the passenger axle goes into. Is that what you need? Its from a 90 ls trans.
Old Jul 26, 2011 | 11:51 AM
yeah thats what i need the last part the cone looking part. and yea well my car is pretty low.
DA KING
May 26, 2006 01:38 AM
roycivic92
Nov 14, 2005 11:03 AM
MTK Kommander
Jul 13, 2002 12:37 AM
