h22 in cb7, can i re-ring/piston swap with motor in car?
Old Jul 24, 2011 | 11:31 AM
usdmftw's Avatar
Default h22 in cb7, can i re-ring/piston swap with motor in car?
i have a h22a4 in a cb7 and either have shot rings or broke ringlands. if the cylinder walls are good can i remove pistons with motor in the car? i have done it with with b series but just wanted to make sure balance shaft or nothing else would be in the way. i obviously plan on removing the head etc. i just dont want to have to pull the motor if i dont have to, i am one person and do most of my work alone and i can remove a head easier than removing the motor by myself. thanks for any advice.
Old Jul 24, 2011 | 11:33 AM
nus_dogg's Avatar
Default Re: h22 in cb7, can i re-ring/piston swap with motor in car?
You can do it with the block still in the car. I know there's one dude who did it.
Old Jul 24, 2011 | 02:52 PM
usdmftw's Avatar
cool thanks, the only thing idk about is balance shaft, this is the first h22 i wqill be opening and i did not know if it somehow was in way and would not allow to push up pistons. i have done it a few times with b series in eg/ek's.
Old Jul 24, 2011 | 03:11 PM
GhostAccord's Avatar
Balance shafts are not in the way. This can be done pretty much the same as a B series.
However, as you mentioned, if it is your cylinder walls/hone. Honing an H22 is not something you can do on your own with a ball hone with the block in the chassis.
Fingers crossed that your issue isn't cylinder wall wear/damage.
mjutila
Jan 7, 2012 09:20 AM
jt-sport
110
Aug 18, 2009 03:07 AM
baller78c4life
21
Mar 11, 2006 12:48 PM
Ri5e
Sep 24, 2003 05:05 PM
