k20a2 can i run aftermarket cams if i have high comp headgasket?
Old Jul 24, 2011 | 11:03 AM
usdmftw's Avatar
Default k20a2 can i run aftermarket cams if i have high comp headgasket?
i bought a k20a2 that has a high comp. head gasket(0.014"). can i run aftermarket stage 1-2 cams without clearance issues? i know its best to properly check clearances but thought someone might know how to calculate the numbers and maybe tell me, or if someone else had exp. using .014" HG with cams. looking to buy some cams and want to know if i should order a oem head gasket. but if it will work would not mind bump in compression. thanks for any advice.
Suck my DX
19
May 19, 2006 02:16 AM
B16Civic93
Dec 30, 2004 06:53 AM
jdmcx
Dec 21, 2003 06:34 AM
VTEC-DA
Mar 7, 2003 12:14 PM
TmeX05
Dec 29, 2002 09:55 PM
