Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
View Poll Results: Have you experienced a blown headgasket with your Civic?
Yes
50.00%
No
50.00%
Voters: 22. You may not vote on this poll
2001 - 2005 Civic Blown Headgaskets
Old Jul 24, 2011 | 05:56 AM
john222's Avatar
Default 2001 - 2005 Civic Blown Headgaskets
Who has experienced a blown headgasket with there gen 7 Civic.
Old Jul 24, 2011 | 06:58 AM
Orangegsx's Avatar
Default Re: Civic Blown Headgaskets
Pretty common it seems.
Old Jul 24, 2011 | 12:48 PM
EM2abe's Avatar
views and only 7 votes? sheesh....
Old Jul 25, 2011 | 12:56 PM
z4nd's Avatar
Default Re: 2001 - 2005 Civic Blown Headgaskets
Yes but it was my fault.
Old Jul 25, 2011 | 12:57 PM
m_shake's Avatar
There a reason we keep top end gasket kits for these civics in stock at my dealer lol
Old Jul 25, 2011 | 01:10 PM
john222's Avatar
This must be a tough poll, over 100 views and only a handful of votes. Come on guys, man up! Simply answer yes or no.
Old Jul 25, 2011 | 01:27 PM
m_shake's Avatar
Maybe no one on honda-tech drives 01-05 civics for several reasons...
Old Jul 25, 2011 | 03:17 PM
Maple50175's Avatar
I have blown over 4 headgaskets. then again I have been boosted.
Old Jul 26, 2011 | 02:21 AM
rmdevo's Avatar
I apparently have a blown head gasket. I have not had it fixed yet , but I barely use my car to avoid overheating. I still am skeptical that it is a head gasket. I see posts here where people suggest the problem is caused by a clogged radiator.
The lack of response here shouldn't be interpreted as lack of a real problem .People who have had their car repaired probably stop checking this site for solutions.
Old Jul 26, 2011 | 06:57 AM
EM2abe's Avatar
There is almost no reason that your radiator would be clogged. Unless it's clogged by air that has escaped from the motor into the coolant passages in the head gasket. or unless you ran some intense amount of stop leak through your system....
Old Jul 26, 2011 | 08:39 AM
GriFFIthS's Avatar
I drive mine like its stolen the best of times, lol. needless to say i certainly do no baby the car, it sees high rpms fairly often, it has 177,000 km's and my head gasket is just fine.
Old Jul 26, 2011 | 09:57 AM
TailZ's Avatar
It's possible for a radiator to be clogged. My radiator was clogged as it always shot the coolant through the reservoir. First thing I learned here was "it's sounds/most likely the hg." That's not always the case. Went to a shop and had a combustion leak test performed. Everything was normal. Then the shop realized that only one side of my radiator would get hot and the other cold. I replaced the radiator and bled the system like I always do. No overheating problems yet.. *knocks on wood* fyi been about 2 weeks?
Old Jul 26, 2011 | 03:12 PM
civx23's Avatar
i had a blown headgasket on my 03 civic prob around the 155,000 mark...i just couldn't vote to say yes...i'm still a 'trial user'...and from what i heard its pretty common.
Old Jul 26, 2011 | 05:08 PM
Harlowe's Avatar
Function>Fashion
mine never BLEW, but it leaked coolant into the cylinder on one cylinder... I would have burp the system and add coolant every couple weeks, oil and coolant never mixed. But that engine is long gone........
Old Jul 26, 2011 | 06:01 PM
soon2bdropped's Avatar
hmm i dont see this as a common issue at my dealer??
Old Jul 27, 2011 | 08:33 AM
EM2abe's Avatar
Usually if there is a cooling problem, I will check both sides of the radiator and both hoses as a first approach... Yours is the first that I've heard being clogged. I have only heard that it could happen, but I have not heard of it actually happening until now. Are you the first owner?
Old Jul 27, 2011 | 10:24 AM
TailZ's Avatar
Yeah totally forgot to check the rad and actually touch it because I was already convinced that it would be the hg(due to coolant filling reservoir symptoms). The water pump was replaced 4,xxx miles ago along with the timing belt. I was told to start off by replacing the small things such as the radiator cap and thermostat. I am actually the second owner.
Old Jul 27, 2011 | 01:29 PM
john222's Avatar
That's a blown headgasket.
Old Jul 27, 2011 | 02:58 PM
EM2abe's Avatar
Maybe the first owner had a coolant leak or something and decided to put stop leak in there or something..? i dunno.
Old Jul 27, 2011 | 04:58 PM
TailZ's Avatar
yeah that's def. a possibility. that stuff can screw $hit up.
Old Jul 27, 2011 | 11:21 PM
ekmoser's Avatar
I just had my water pump fix around 165k then found out car over heat due to head gasket blow at 165k
Old Jul 31, 2011 | 05:36 PM
BoostedBuggy's Avatar
Could a blown head gasket cause an engine misfire?
Old Jul 31, 2011 | 06:02 PM
yes it can..
new_climber
Aug 28, 2023 12:11 PM
James Tuttle
Mar 1, 2017 10:20 AM
SLO Sol
Nov 21, 2005 12:08 PM
townethug
11
Sep 17, 2004 12:35 PM
therealnapster
Sep 10, 2001 01:32 PM
