Honda S2000 Honda S2000
need help on rear suspension
Old Jul 24, 2011 | 03:19 AM
dojo19xx's Avatar
Default need help on rear suspension
Hi
im new here and i need your help
i just bought a 2001 ap1 with 30k miles.
the car drives great but the only thing that bothers me is that the rear of the shakes when one or two tires pass thought gaps.
the previous used to run on coil-overs so i guess he might didn't install the stock suspension properly.
and also i hear some noise from rear.
please let me know if anyone have had same problems before.
thank you for your time.
Old Jul 24, 2011 | 04:26 AM
JUSTINTHECOASTI's Avatar
Default Re: need help on rear suspension
CV axle buckets are worn, replace them
Old Jul 24, 2011 | 05:54 AM
justinsbg's Avatar
Inner CV joints are probably worn. It's a fairly common problem. Does you feel a shake from the rear on acceleration?
Old Jul 24, 2011 | 01:20 PM
dojo19xx's Avatar
thank you JUSTINTHECOASTI and justinsbg,
i do hear clicks and pops on acceleration,
so which parts i need to purchase and is it expensive?
Old Jul 24, 2011 | 03:02 PM
Here's the best way to explain http://www.s2ki.com/s2000/topic/2413...diy-with-pics/
Old Aug 19, 2011 | 05:43 AM
Vyndictive's Avatar
It could also be the rear axle nuts need tightened. That's fairly easy and common on the early AP1s.
Old Aug 19, 2011 | 07:13 AM
nizmo_max's Avatar
OR just get half shaft spacer..easy fix!!!
Old Aug 19, 2011 | 02:22 PM
mamoonkay's Avatar
May be you need half shaft spacer
Old Aug 21, 2011 | 01:42 PM
bigmacnfries's Avatar
what's a thought gap? or am i having one now?
Old Aug 21, 2011 | 03:01 PM
Boots's Avatar
i have at least 5 thought gaps a day
Old Aug 21, 2011 | 04:47 PM
have you ever passed a thought gap like this fellas tires though? No wonder his rear shakes
Old Aug 22, 2011 | 09:48 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
just swap them out... youll be set...
H8BOOST
Honda S2000
10
Jun 22, 2010 02:00 PM
ilper
Suspension & Brakes
Oct 11, 2008 01:19 AM
Hehehe I just
Honda Fit
10
Apr 20, 2006 12:40 PM
chiheat
Honda S2000
May 16, 2005 09:55 AM
Vracer111
15
Dec 23, 2003 11:49 AM
