FS/FT B/D-Series Turbo Parts&More...56k Go Bake A Cake
Hey whats up Honda-tech.Im sure you have seen Very many of my forsure Threads &More....So Last Night..I Melted a Piston in my LS-T 15 PSI...So now i need to make Some cash To Build a Reliable turbo Set up...So all this stuff im looking to Upgrade to bigger...
Name Zack Phone Number 724-984-2168 Location Uniontown,Pennsylvania
PARTS IM LOOOKING FOR
B-Series Top Mount or Ramhorn Manifold T3 Flange
800cc or Bigger Injectors Nothing over $250
Tial Wastegate LMK What u got
STAGE 3 or Better clutch Disc
Eagle H-Beam Rods B18A/B
ARP HEAD STUDS B18A/B
JUST LET ME KNO WHAT U GOT
Updated Items
1. P-FAB D-Series 304 Stainless Steel Turbo Manifold...1,500 Miles...My buddy paid $335.00 on ebay Im asking $205.00 Shipped
(Or will Work in on a Trade for a B-Series Top Mount or Ramhorn)
3.NEW Garrett Turbo...GarretT says its BB &850hp....In .60 Ex 1.15....T4 Divied Flange...Its a Super Nice Huge turbo.....New is Over $900.00 Taking Best Offers Or will Take Trades (This Turbo is the One on LEFT)
4.GARRETT GT28 In.60 Ex.48 T3 Flange/5 Bolt DP Flange....Needs Rebuild...Only Reason is Because Didnt run Oil restricter So i blew Oil seals...Spools Really Nice.....$200.00 shipped Will work on trade
(In First Turbo Above its the turbo on RIGHT...Compressoer Housing is Ported)
5. Hasport Driver Mount...My bro Used on his H2D...He Shaved it so it would set right...im pretty sure there either 85A or 90 A Mount...$60.00 Shipped Or work in trade
6.HF Manifold...Used for Turbo Manifold...All you Need is a $20 Adapter Plate from ebay &Slap ur turbo on it...$30,00 +Shipping
Pioneer 6 Disc CD Changer $10.00 Shipped /Lighting Audio 750 watt amp $40.00 shipped /AUDIO PIPE 12" 750 Watt Sub $65.00 + shipping
7.AIRTEX 190LPH Fuel Pump For 88-91 civics/integra (retail $165.00 Still new in box.Box is a lil dusty from settin cant use i got EG $50.00 Shipped
~DSM 390cc Injectors $75.00 Shipped OBO
~P06 OBD1 Mt ECU $65.00 Shipped /P07 OBD1 mt ECU $50.00 Shipped
P2E OBD2 AM ECU $40.00 Shipped
8.96-99 Manuel Gauge Cluster(No tach)$35.00 Shipped
~92-95 Civic Manuel Gauge Cluster No tach $25.00 Shipped
9.Snow Board Only used 3 times...I got Messed up so never rid it again..Its in awesome condition...Minor scratchs on bottom...This board is Legit u barely have it have a hill for it to start rolllin...Paid $379.99
Ill take $90.00 +Shipping
10.OBD0 D16A6 PGMFI intake manifold...Includes Injector clips...What u see is what u get $40.00 +Shipping
11.94 Integra GSR Black Passenger side Air Bag $40.00+sHIPPING /EG Civic Blower motor $32.00 Shipped/EG cruise Control Unit $20.00 Shipped
12.92-95 Civic Grey Center Dash Console thing...Can include Clilmate Control Unit $40.00 Shipped For Both or $22.50 Each
13.96-99 Civic Pillow Mount Only 20k on it No Ripps....$35.00 Shipped
14.AirFlow Research 6" Filter/w Aluminum Volcity Stack...Was for a 07 BMW...But i used it on Turbod Civic...I got a Nice 3" Coupler on end of Aluminum so the volcity stack goes right on to 3" Tube $85.00 Shipped For this
15.88 CRX SI Taillights...This Picture does not do them Justice...There Freshh...No Harness wit them...$70.00 Shipped
16.94 INTEGRA GSR Sunroof Assembly...Also Sunroof Switch Included(Not the harness for this...$65.00 Local Pick up ...Can shipp at ur expence
17.96-98 Civic Sedan(4door) Primer Black Trunk Lid its Fresh tho..$35.00 Local Pick Up only ALSO Have the Taillights for sedan in great condition $40.00 Shipped for Tails
18.Bouch of Random Sensors If you see somethin u need Hit me up an we will work a deal..A/C Compresser $40.00 +Shipping....OBD2 GSR Crank Sensor $30.00 Shipped...And Rest is BEST OFFER
19.4 lower OBD1 b-SERIES Timing Covers $10.00 Shipped Each /1 OBD2 GSR Lower timing Cover $15.00 Shipped/SOHC TOP&BOTTOM Timing Covers $15.00 Shipped Each
20.DRAG B-SERIES T3/38MM Turbo Manifold Awesome Condition $100.00 Shipped /SILVER 38MM External Wastegate $42.50 Shipped
21.Nitrous Brand 0-30 psi Vaccum Gauge $12.00 Shipped
22.D16Y7 OBD2 Distributor...Its a Reman Has 9k Miles..Blue Rice Clear Cap $55.00 Shipped /D16Z6 OBD1 Fuel Rail/Injectors/Injector Clip Harness $45.00 Shipped/(2)D16Z6 Fuel Rail $12.00 Shipped Each....F20B Euro R Fuel Rail $25.00 Shipped....F22 old School Fuel Rail $12.00 Shipped /Brand New JDM Knock Sensor $45.00 Shipped/OBD2 GSR Map Sensor/w Pigtail $40.00 Shipped/92-95 Civic CX Map Sensor(The one that u run Vac line to $20.00 Shipped /Good TPS $20.00 sHIPPED/ HOLLY Chrome FPR...Its for Low Psi for Carb motors $15.00 Shipped/D16Z6 AUTO Throttle Body Has TPS/No Map $30.00 Shipped/OLD School/CX Civics Honda Metal Center Caps...Not rusted out Got 5 of them $30.00 fOR ALL 5 or $7.00 Each
23.D16Z6 SOHC VTEC HEAD....Has LMA...CAM......Does not include...Valve Cover,Vtec Sol,Valves,Springs,Retainers,Dizzy or Intake Mani $45.00 + Shipping ////PERFECT FOR A BUILD HEAD
24. 3" Exhaust from DP Back to where it starts to bend...That S bend on back needs cut off an i got a couple More modenl Bends go wit it i ran it side pipe BEST OFFFER
25.94 integra GSR P/S Rack...Missing 1 outer Tie rod $50.00 +Shipping
92-95 Civic P/S RACK $45.00 +Shipping
~3" Intake Tube For 92-00 Civic No Y7 ...Thgese go for $55 at advancer...$25.00 Shipped
~96-00 Gauge Cluster Bazel 2 gauge Pod...$12.00 +Shipping
~OBD1 P06 5 SPEED ECU...$65.00 shipped
~OBD1 P07 5 SPEED ECU...$50.00 SHIPPED
~96-99 CIVIC 5 speed cluster with no tach $30.00 shippedd
~92-95 Civic Under Dash Harness $50.00 Shipped
~Air Flow Reasearch Aluminum Volcity Stack/w 6" Filter $120.00 Shipped
`92-95 Civic 5 SPEED GAUGE cluster/No tach $25.00 Shipped
1.B18A1 Valve Cover..Cut for Cam Gears $30.00
2.B18B1/B20 Valve Cover Cut for Gears...$40.00
4.VSS for B series Cable Tranny...$25.00
6.IVAC Valve for H22...$25.00 /IVAC FOR OBD0 B16a $25.00 /IVAC for B18B1 $25.00
10.B-Series Half Shaft its a Female on where axle Goes...$35.00
11.B18A1 Head..Its Super Clean...I think its a Reman Head it was I swear brand new when i bought...Has 2 Broke cam cap bolts but easy fix...Head is complete $100.00 Obo
12.B18A1 BLOCK, Has all Internals...And are all perfect...Needs a Fresh Rebuild...$100.00
13.B18C1 OEM Flywheel 51k Miles/w OEM Replacement Pressure Plate 5k Miles....$45.00 For both as Combo
14.D15B2 Brand New OEM Replacemnt Pressure plate...Has tiny bit of surface rust from settin $25.00 Obo
16.92 Civic EX Black Dash/ HAS Air bag.. Does not Include cluster or botttom console...$75.00
17.D16Y7 OBD2A Auto Ecu $30.00 /OBD1 P07 Y5 ECU(Can be chipped and used just like P06/P28 etc $50.00
20.Alot of EG Interioer pieces &Window switchs etc
21.94 Integra LS Black Pass side Power door panal$20.00
23.95 Civic EX Power Steering Rack...$60.00
24.96 Integra GSR Power steering Rack $65.00
25.95 Civic Ex front Sway Bar $25.00 Obo
27.92-95 Civic Powersteering SET UP Pump,belt,bracket,Lines etc $70.00 Obo
28.92-95 Civic (3) Cruise Control Units...Ive got Cables for them to $20.00 Each
29.95 civic Ex 15/16 Brake booster/master /92 civic cx 13/16 Brake booster/master
30.95 civic Hydro tranny line from Slave to Clutch master $35.00 Obo
31.B16A OBD0 BARE INTAKE MANIFOLD $20.00 Obo
32.Grey 96-99 EK Front Seats...Super Lite...No tracks but got some...$35.00
33.92-95 Civic Power Mirriors Driver&Passenger side...$40.00 For set
SOLD TO(BoOsTdTeG)26.92-95 Civic Front Spindles...Mint wheel Bearings $50.00 Each side
SOLD TO (Baller8728)22. 96-99 Civic Coupe Mint taillights $45.00 /96-99 Civic 4 door Taillights $40.00
SOLD Local 18.95 civic Ex Trunk Lid No spoiler...Burnt Orange Color...Mint...$45.00 Obo
SOLD LOCAL 19.95 Civic Hatch Rear Bumper..Needs painted...$35.00 Obo
SOLD LOCAL 15.B16A Block/Mint Crank/Rods/ Disassembled....Has Oil pump an everything...Block was resurfaced 2k Miles ago...Used pistons in my LS....No pistons $175.00
SOLD LOCAL
Updated Items
SOLD LOCAL
eh vtec sc
Sep 17, 2010 05:20 PM
boostedgsr1234
Feb 6, 2009 03:44 AM
boostedgsr1234
Dec 16, 2008 05:39 AM
Dwolt226
Feb 17, 2008 06:20 PM
KeyserSoze
Apr 5, 2006 03:31 AM
, buyer here soon haha.
