Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 honda civic rattling noise
Old Jul 23, 2011 | 10:03 PM
zashton26's Avatar
Default 2004 honda civic rattling noise
hey just have a quick question for anyone. does anyone know what could cause a rattling noise? so far its none of the following ive had each done to see if they were the cause... new sparkplugs and ignition coils , new serpintine belts, new air filter... anyone who has an ideai would appreciate it
Old Jul 24, 2011 | 07:27 AM
Pothole987's Avatar
Default Re: 2004 honda civic rattling noise
rattling like metal on metal? i would guess a heat shield is loose.
Old Jul 24, 2011 | 11:25 AM
zashton26's Avatar
Ive checked the heat shield and its fine it only happens every once in a while.... someone said it could be the timing belt but idk
Old Jul 25, 2011 | 06:54 AM
Pothole987's Avatar
the timing belt is rubber so it wont be rattling. its hard to tell you anything without seeing it. just start the car up, let it run and try different things like steering left right, ac on and off.
theres more than the one heat shield on the car too. i think theres 3?
Old Jul 25, 2011 | 07:03 AM
techtalk's Avatar
zashton,
Which heat shield have you checked out? If the rattling sound is originating from the engine bay then I would hasten to surmise that your exhaust manifold cover is loose. (or it may even have an exhaust leak- I'd check for that as well because this can cause a "tapping/rattling" sound at idle and low rpms) I would also check to see if the two covers directly underneath the exhaust manifold cover (ref # 5 and 6 in this Civic exhaust manifold diagram)are loose.
Good luck tracking down the source of the rattling sound- nothing boils my oil more than an incessant rattling noise!
Old Jul 25, 2011 | 09:19 AM
K24_Y61P's Avatar
Its either one of the eighteenmillion heat shields or your tires. My bet is a heat shield. Crawl back under and check them all from the header (yes header not headers) all the way to the exhaust tip.
Old Jul 25, 2011 | 10:17 AM
toyomatt84's Avatar
Sanji
Does it happen while driving primarily? Is there a clunking feeling combined with it?
Old Jul 25, 2011 | 12:41 PM
zashton26's Avatar
thanks ill check those spots out.... toyomatt84 its normally at idle when i here it
Old Jul 28, 2011 | 12:58 AM
roach4201986's Avatar
when is the last time you changed the oil??? are you sure its not a rod knock??... loose motor mount?? maybe??
Old Jul 28, 2011 | 04:28 AM
toyomatt84's Avatar
Sanji
Have you inspected your engine mounts? They could be worn.
Nick_s110
Honda Civic (2006 - 2015)
Jun 25, 2018 01:20 PM
angela r m
Feb 4, 2016 04:51 AM
tonykdee
11
Dec 15, 2009 10:43 AM
ixsan25
Apr 12, 2008 06:43 PM
hondaciviclover
22
Aug 10, 2004 10:22 AM
