Bead-blasted... now what ?
Old Jul 23, 2011 | 02:08 PM
X2BOARD's Avatar
Default Bead-blasted... now what ?
I have a set of rims I want to repaint/powdercoat.
Whats already done to the rims:
1) Paint completely stripped
2) Surface bead-blasted to the base aluminum.
3) Washed and out gassed in an oven
What is the next step to painting them ?
Sand/scuff, prime, paint ? Are all three steps necessary given the metal is already bead blasted ?
The plan is to spray paint them and hit them with a clear coat of powder.
Old Jul 26, 2011 | 09:12 AM
HybridKOOP's Avatar
Default Re: Bead-blasted... now what ?
I would sand them with 320 or 400 dry, alcohol them clean, then use a quality etch primer as your very first layer of product on them. This will promote adhesion, and will seal in the metal before you use a thicker, sandable primer before paint/powder, etc. I really like DuPont's Variprime I believe it's called.
Lou
btraut
Sep 10, 2012 04:37 PM
greasmanky
Dec 4, 2005 08:39 AM
Thrillhouse
Sep 12, 2002 10:30 PM
PurpleGsR00
May 28, 2002 12:59 AM
