CKP code on JDM B20 swap HELP!!!!!!
Old Jul 23, 2011 | 03:22 AM
hondaclown's Avatar
Default CKP code on JDM B20 swap HELP!!!!!!
I have put a brand new dizzy in still same code engine runs like crap, will not rev over 3500 and then cuts out till you let off the gas. After warm up it will not idle. I am at a total stump on this thing!!!!!!!!
I have a 99 EK with a 99 B20 JDM engine
P28 ECU Hondata S300
obd2 to obd 1 jumper harness
HELP PLEASE!!!!!!!!!!!
Old Jul 23, 2011 | 07:06 AM
hondaclown's Avatar
Default Re: CKP code on JDM B20 swap HELP!!!!!!
come on some one help me PLEASE
Old Jul 23, 2011 | 07:17 AM
Deetz's Avatar
Crazy Honda Guy
The last jdm b20 i ran, i just use an obdI PR4 ecu with jumper, and the car ran mint.
Not sure why you are having issues with your p28 s300 setup. I wonder if it is because you are using a newer obdIIB dizzy, because the P28 has the crank angle sensor built into the older distributor for it's generation
Old Jul 23, 2011 | 10:50 AM
appelsos's Avatar
if you are truly running obd1, you shouldnt be getting this code at all because there was no crank sensor on obd1 cars.
techabe12
Sep 12, 2016 05:29 PM
Midnight_runs
Nov 20, 2013 06:02 AM
demael93
Oct 25, 2013 05:27 AM
94DB7integra
Mar 29, 2012 08:53 PM
Jwbetley
Oct 24, 2008 07:46 PM
