CA 1996 original Midori Hatch w/ Acura MDX key holes.
$3200 takes it home today!
ACURA KEY HOLES! DRIVER , PASSENGER, AND trunk!!
I need to get rid of my whip Asap so heres wat it got
Too much to list
Engine:
fresh JDM ZC D16z6 head p28 ecu obd2 - 1 jumper
Rebore, resurfaced, REBUILD TOP N BOTTOM
Starting 5/7/11
everything less then 100!
I drive it everywhere and it's perfect funs
guaranteed another 100,000
DISTRIBUTOR FROM O REILY PARTS 0 MILES!
75.5 MM VITARA PISTONS LOW COMP TURBO PISTONS
Got brand new valves, seats, retainers, springs
Spark plug
Ngk wires
Brand new Gates timing belt 0 miles
Jdm d15b water pump
Transmission:
0 miles brand new aftermarket clutch
S20 transmission with LSD reBuild 1st gear
Has been converted to manual so it starts without clutching
96 - 98 ex harness obd2
Si fuse box
Straight piping
SI MASTER CYLINDER
OEM CYLINDER SLAVE
STEEL BRAIDED CLUTCH LINE
oem stock strut with skunk2 coilover sleeves
Car has been converted to SI disk brakes
Pad and rotors at 5k oem
Interior:
Ctr cluster 76k
Ctr cup holder
Ctr delete airbag
Ctr cup holder
CARBOM FIBER e brakes console/panel (the one goes where the shifter is.)
Sparco steering wheel
MOMO HUB
C pillar
CUSTOM suede headliner
CUSTOM yellow stitching door panel and SI arm rest
Half gutted half interior
BATTERY RELOCATED TO BACK SEAT
MEDIUM WIRE TUCK
LIFETIME WARRANTY SERVICE ALIGNMENT FROM firestone
EXTERIOR:
Carbon fiber hood
Depo fog lights
Xenon hid
Fit hub caps
POOR MAN TYPE R HEAD LIGHTS.
SI side skirts black
The bad:
NO REAR SEATS
NO CARPET
Few dings n scratches
DENT ON TRUNK BUT FIXABLE
Best way to reach please call 626-234-8291 asking $3200 firm
Too much to list
Engine:
Starting 5/7/11
Spark plug
Ngk wires
Jdm d15b water pump
Transmission:
Si fuse box
Straight piping
SI MASTER CYLINDER
OEM CYLINDER SLAVE
Interior:
Ctr cluster 76k
Ctr cup holder
Ctr delete airbag
Ctr cup holder
MOMO HUB
C pillar
MEDIUM WIRE TUCK
EXTERIOR:
Carbon fiber hood
Depo fog lights
Xenon hid
Fit hub caps
The bad:
NO REAR SEATS
NO CARPET
ducsaim
Aug 27, 2011 04:23 PM
ducsaim
ducsaim
Aug 3, 2011 02:56 AM
