wttf NEED A/C setup for EG hatchback
Hey guys I need a full A/C setup for an EG hatch minus the blower motor and the a/c controls that go inside the car on the dash, I made a deal with some body for a complete a/c system and the kid has ****ed me and never sent me **** after I sent him a brand new walbrough 255 fuel pump AND a brand new 15lb NOS bottle on the assumption that he was a stand upp guy who would hold up to his end of the deal and NOT screw me over...
I live in south Florida so you know how sweltering hot it gets down here with no a/c in the car
I dont have any money to offer BUT I do have a SHITLOAD of items to trade for the a/c setup and I will gladly send you MULTIPLE item in exchange for the a/c system
PLEASE help me out guys
Also if you live in south Florida I also do high end car audio installs including fiberglass,wood boxes,vinyl and leather wrapping as well as alarms and ANY type of 12 volt electronics you may need installed into the car...I have 15 years experience doing that kind of work and my work is top notch and second to none
These are the items I have as of right now to offer up for trade BUT I am sure I have other items that I just have not listed
1) Pac C2R-CHY2 With harness = Retail is $35.00
2) 2 Stock srt-4 shifters = Retail $35.00 each
3) Tsunami Dual glass fuse holder "One" 4 gauge input and "two" 8 gauge outputs = Retail $20.00
4) Brand new Fierce audio Ground loop Isolator "FIGLI" $10.00
5) Round terminal cup w/ screw down terminals $15.00
6) 12 feet of Install bay "9"wire" $15.00
7) Silver/chrome Honda shift **** 5 speed $8.00
8) 6 feet of Install bay 9 wire $6.00
9) 5 1/2 ft install bay 9 wire $ 6.00
10) 4 ft Install bay 9 wire $ 5.00
11) 5 ft of Kicker Hyperflex 4 gauge "with blue shield" 1862 strands in this wire $ 9.00
12) (2) 1ft kicker hyperflex 4 gauge black 1862 strands $ 3.00 EACH
13) 3 1/2 ft 4 gauge Blue kicker hyperflex 1862 strands $6.00
14) 22 inches blue kicker hyperflex 1862 strands $ 12.00
15) 24 inches blue kicker hyperflex1862 strands WITH ring terminal $ 11.00
16) 12 inches Red Rockford phosgate 4 gauge WITH ring terminal $9.00
17) 30 Inches of 4 Gauge Kicker hyperflex blue 1862 strand count $17.00
18) Sirius portable radio cradle for " sporster,starmate " $10.00
19) Sirius portable radio cradle for " sporster,starmate,stratus " $10.00
20) Alpine CDA-7893 FACEPLATE ONLY "PERFECT CONDTION" and everything on the faceplate works fine as I tested it $ 40.00
21) Alpine RUE-4203 remote control $ 20.00
22) Brand new Rockford Phosgate battery terminals W/ 2 8 gauge terminals $ 12.00
23) Dremel brand engraver model number 290-01 almost brand new "used 4 times" $ 25.00
24) 24 inches 4 gauge Rockford Phosgate wire red $ 8.00
25) 30 inches 4 gauge kicker hyperflex blue 1862 strands $ 18.00
26) 22 inches red rockford phosgate 4 gauge $ 10.00
27) 12 inches 4 gauge Tsuname competition $ 5.00
28) 40 Inches 8 gauge kicker hyperflex WITH black techflex loom AND heatshrink on ends $ 25.00
29) 23 feet 8 gauge RED kicker hyperflex $ 35.00
30) 18 1/2 feet 16 gauge kicker hyperflex speaker wire "blue/silver 111 strands $18.00
31) 9 1/2 feet 16 gauge kicker hyperflex speaker wire blue/silver 111 strands $9.00
32) 2 feet Rockford fosgate4 gauge wire red $ 8.00
33) 22 inches rockford fosgate red $9.00
34) 22 inches red 4 gauge rockford wire $ 12.00
35) 22 inch red 4 gauge rockford wire $12.00
36) 15 inches red 8 gauge rockford fosgate $ 4.00
37) 28 feet Kicker "O.F.C" "oxygen free copper" 16 gauge hyperflex speaker wire 111 strands blue/silver $23.00
38) 22 inches 4 gauge red monster cable wire $12.00
39) 30 inches Red 4 gauge rockford fosgate power/ground wire $14.00
40) 30 inches Red 4 gauge rockford fosgate power/ground wire $14.00
41) 10 inch long 4 gauge ground wire WITH black techflex, heat shrink on both ends AND 2 silver 4 gauge ring terminals $35.00
42) 23 inch 4 gauge red rockford fosgate wire $8.00
43) 21 inch 4 gauge red rockford wire $8.00
44) 25 inches of 4 gauge red rockford fosgate wire $10.00
45) 55 inches of 16-20 gauge primary wire "VERY NICE" $5.00
46) 26 inches red 4 gauge rockford red power wire $12.00
47) DEI 519H2 garage door opener/interface "allows you to open automatic garage doors from your alarm remote $ 60.00
48) Jensen 300 watt power inverter $40.00
49) fmda25 sirius fm modulator $18.00
50) sirius antenna $14.00
51) sirius stratus $25.00
52) axxess 4 channel adjustable line out convertor ALOC648 $15.00
53) xm roady XT car cradle $15.00
54) Blue point/snapon YA1201 door panel remover $8.00
55) Actron CP9125 pocket scan code reader/code scrubber out 3 1/2 amps,soft start,displays "mil" status displays codes and works with OBD2 $ 50.00
57) Vector VEC 1024 400 watt power inverter puts out 3 1/2 amps to power laptops,radios,small tv's AND tools $30.00
58) Double din radio cage $25.00
59) 4 inch MDF speaker rings $8.00
60) Pioneer CXC1224 radio remote control $ 30.00
61) Nitrous fuel cheater solenoid Part# 16050 $25.00
62) Dei 508D proximity sensor $60.00
63) Scosche BFGM "new never used" includes non xm radio harness bluetooth interface for adding bluetooth AND bluetooth controls to factory GM radios $ 200 "retails for $260-$300 dollars"
64) Peripheral I-Simple IS31 Universal fm modulator for Ipod/Iphone charger, allows you to play Ipod/Iphone through ANY fm radio station $ 30.00
65) Axxess ASWC universal OEM steering wheel controll interface adapter, works with ANY car and ANY radio that has sterring wheel control inputs "retails for 60-80 dollars" mine is brand spanking new for $50.00
66) AI Xterminator S-15A noise filter 250 watt $10.00
67) Scosche FAI3A 2/4 channel LOC $15.00
68) Jensen remote control BRAND NEW
69) DEI BITWRITER BRAND SPANKING NEW, Allows you to program ANY feature on an alarm than the alamrm is capable of withought having to go through the god awful menu, easily saves 35 minutes off of the time it takes to program an alam $80.00
