1st gen b16 CRX OIL PUMP FML...
So, I'm having this problem. After driving my car hard or for a long period of time my oil light cuts on and the bastard dies on me. So i changed the oil, then oil sending unit, come to find out i need an oil pump....
What oil pump can I use, cause I'm having hell finding one? Thanks
You should have no issues finding one, any b series pump will work. It's best to have the vtec version though, as if flows better.
For a direct replacement for your 1st gen, use a 92-93 gsr, or a 94-95 del sol B16 vtec pump
you sure its the oil pump? what led you to this conclusion? from the description it sounds like the rod bearings (but I hope not!)
if trash went through your oil pump and destroyed the clearances, it probably did more damage. look for copper colored flakes in the oil. I hope (for your sake) they're not present.
btw, i have a 1st gen b16 in one of my cars, i know it well. The oil pump you want for a direct replacement would be the two models i already mentioned! Reason being, they did not have the provision for the crank fluctuation sensor that was found on b seires 96+. Yes, you can buy the newer pump, you would need a newer lower timing belt cover too, just to make it fit, but why bother when you can get the proper fitting one from the older model in the 1st place
I worked for Honda for years, i know all about b series oil pumps. They do all fit the the block the same way. Here is a pic of what the outside differences look like
And, "if" you buy the newer pumper, you will have to switch from one timing cover the another also, as shown
USDM 4G VTEC
Sep 9, 2003 01:19 AM
