H22 Go Really Fast Goodies...Don't miss these deals!
In reference to all the items listed below please use the following contact info:
Honda-Tech PM should go to username rxspeed88
text message to 8286121712
I WILL TRADE FOR A RUNNING 4 DOOR INTEGRA! I WOULD REALLY LIKE A GSR.
I CAN TAKE ANY PICS THAT ARE NEEDED!!!
ive had this thing going on since november and im honestly just tired with it.
its a fully built h22a.
T1 spec je pistons. custom made per T1 specs. (Thanks to TOPENDUSA!)
T1 spec manley turbo tuff rods (THANKS TO TOPENDUSA!)
darton mid sleeves
honda oem bearings
head has been port and polished (looks amazing)
kms springs and titanium retainers
cometic head gasket
stock size valves
crower stage 2 boost cams
motor is fully blueprinted
arp main and head studs
arp rod bolts
kaizenspeed balance shaft delete ( THANKS TO TOPENDUSA!)
kms hi flow oil pump (THANKS TO TOPENDUSA!)
venom intake manifold (THANKS TO TOPENDUSA!)
str fuel rail (THANKS TO TOPENDUSA!)
omni 70mm t body
Ive got over 1600 just in machine and head work Herringtons in taylorsville did all the work.
3500 for the long block
up next is the turbo manifold.
its a custom made top mount from blaast performance out of canada.
it was also custom made per T1 specs
its been ceramic coated and it looks amazing
t4 split flange
dual 38mm wastegate v band flanges.
i have 2 tial mvr gates for it. they are brand new never used
1300 for manifold set up
ill take 4200 for the whole set up together.
i dont have to sell this and as far as im concerned it can sit. i would just like to clear some money up and work on another project. i will not break the motor up unless you have some serious cash. check the prices on ebay and then look at what im selling it for. all this stuff is brand new with zero ZERO miles on the engine components. the pistons and rods are good to 1200 hp. i was hoping to hit 750 with a s372. I have a built h22 transmission with a twin disk set up that i will also sell. I can take pics of it as well
i will entertain certain trades as well. throw me some offers.
pics are in the process of being taken and some are on my build thread
darton mid sleeves
honda oem bearings
cometic head gasket
stock size valves
arp rod bolts
omni 70mm t body
t4 split flange
ranta18
61
Apr 15, 2006 01:02 PM
