PA Sick LS6/T56 and very upgraded S13.5..21K
Old Jul 21, 2011 | 07:13 PM
OutToWinPAHC's Avatar
Default Sick LS6/T56 and very upgraded S13.5..21K
Contact Info: outtowinpahc@aol.com
Year: 1991
Make: Nissan
Model: 240SX - LS6/T56 S13.5
Color: Gray
Mileage: 118000
Transmission: Manual
Price: 21,000obo.... If you want a cheaper LS swapped 240 I can point you to the rusty / primered stock LS1 versions or the ones with trannies with grinds.
Description: .
Started build in 2005, made 468 RWTQ back when it was on the old TH350 without the electric waterpump, intake manifolds, and small bolt ons. Should be able to make in the 475-510 area depending on how aggressive the tune is. I just had it retuned by diablo formula racing in May, street tune very smooth.
Located in Philly, clean title, insured, and inspected. Vehicle is insured on my collector policy for an agreed upon value higher then my asking price as well.
Looking for cash, $21K I can make deals to sell it with no headunit,your wheels, a welded diff, no seats, no 2 step, no wide-band or scangauge.
NO TRADES
6.0 Shortblock with 31K avail for $450 to buyer only, 650 to non buyer
Build specs.
Engine
2002 Chevrolet LS6 5.7 Liter V8 block, F-Body accessory drive, GTO oil pan, Texas Speed Ported Blueprinted LS6 oil pump, ARP rod bolts. 48k miles on bottom end, new rear main seal 2/2010 when clutch / trans done.
Heads Valvetrain
Ported and polished 243 63.5cc heads, Patriot racing dual gold springs and hardware, LQ9 rockers with Comp cams trunions and bolts, LS7 Lifters, Hardened push rods, LS2 lifter trays, LS2 timing chain, Texas Speed MS3 cam. Less then 1.2K miles on top end
Intake / exhaust
Weiand Intake, ,Ported screenless MAF, Hooker Supercomp Ford 302 headers (Modified) Dual 2.5 stainless pipe, H pipe, 2 12inch glass packs, 2 Borla XR series mufflers (dual exhaust)
Cooling
Meizer WP319B Electric waterpump, Mishimoto KA radiator, Mishimoto dual fan shroud, 12inch Permacool Pusher, Aluminum cooling panel, 25 Row oil cooler, Remote filter, Moroso bypass block.
Fuel
8 gallon bottom feed fuel cell, Aeromotive adjustable FPR, Walbro 255lph pump, Racetronix 37LB injectors, Auto-gauge fuel pressure gauge on rail
Other
Comp cams Vacuum reserve, Electric vacuum pump 18 to 24 ftlbs vacuum, Optima Yellow top, MSD 2 Step
Tuned by Diablo Formula Racing
Transmission converted from TH350 to T56 in 2010
2002 Rebuilt Tremec T56, D&D syncros, seals, and shift fork upgrade. Spec Stage 3 clutch, Spec Steel Flywheel, -4an SS clutch lines and remote bleeder, Wilcood 7/8 CMC, Custom built 1/4inch crossmember, tig welded with gussets, 1 piece aluminum driveshaft. Less than 600 miles on trans, less than 1600 miles on clutch/flywheel and swap. Built by LSX power and development
Differential
Silvia S15 HLSD in a S14 case with 4.089 final drive, nismo ring gear bolts, energy suspension poly mounts, anodized purple cover, new OEM breather, new oem bolts, Moonface plugs.
Suspension
BC Racing BR Coilovers, Peak subframe collars, Godspeed RUCAs, Megan adjustable traction rods, Megan adjustable toe rods, Custom made S13 to S15 radiator core tension rod brackets, Godspeed front and rear sway bars, Megan tie-rod ends, S14 inners, RP sport braces, Ichiba 5 Lug Conversion, Energy Suspension bushings, Ultraracing Front and Generic Rear Strut bars, Verve Motorsport Powerbrace, Daft CNC swaybar spacers.
Brakes / Wheels
Rebuilt 2009 Nissan Z32 4 piston front calipers, Brembo drilled and slotted rear Z32 rotors, New Nissan Z32 2 piston rear caliper, Nissan Z32 master cylinder, Bonehead lines, Z32 ebrake cable.
Vintage Volk Group AV-3 Wheels 17x8+31 Front, (225-45-17's Nitto Invo 95% tread), 17x9+35 rear (Nitto 555 275-40-17 95% tread) Wheels are very rare and just refinished.
Exterior
OEM S15 Spec R bumper, OEM hood, OEM S15 radiator support and bumper support. OEM S15 fenders welded and merged with metal S13 fenders, veilside side skirts, Lexus Smokey gray metallic paint job
Interior / Safety
Autometer Ultralite 2 gauges, Speedo, Tach, Oil Temp, Digital Oil Pressure, Water Temp, Voltage, Fuel. Level
AEM Uego wide band,
Aeroforce Interceptor Gauge,
Bride Vios seats, Bride FG seat rails
ATI EZ Pod
Center vent pod
Cusco 6pt cage.
RJS 5 point harnesses, SFI rated
VIDEOS
Older Pics
Old Jul 21, 2011 | 08:42 PM
nemotoad's Avatar
Default Re: Sick LS6/T56 and very upgraded S13.5..21K
SICK! glws
Old Jul 21, 2011 | 09:10 PM
srt4mike's Avatar
Bump for viewing.
Old Jul 23, 2011 | 12:56 PM
Thanks. I just picked up a mint All-Trac too, not sure if I plan on keeping it though. Its too mint for me to want to modify.
Old Oct 23, 2011 | 06:43 PM
It has a new owner
Old Oct 26, 2011 | 08:22 PM
blackoutvtec845's Avatar
sexxxxxxxyyyyy. GLWS
Old Nov 6, 2011 | 11:26 AM
driveby4082's Avatar
bump for sick car man
Gnate
Jul 25, 2013 09:20 PM
shawnlee250
Honda Civic (2001 - 2005)
10
Jan 11, 2012 06:34 PM
Adrian Peterson
Wheels
20
Feb 17, 2009 05:16 PM
