power door locks dont work on 90 lx sedan
Old Jul 21, 2011 | 05:59 PM
DCRB's Avatar
Default power door locks dont work on 90 lx sedan
90 lx sedan, everything else works just not the power door locks. The relay box just clicks when the lock button is pushed. I don't see any visual damage to the wiring, will check w dmm and test light for continuity. Trying to install an alarm and would like to use the stock locks instead of running more wires for actuators. Any ideas what could be wrong? I have. A pdf of hondas helms manuals if it helps
Old Jul 21, 2011 | 06:56 PM
ef yu's Avatar
Default Re: power door locks dont work on 90 lx sedan
id swap the control module with a known working one. located in the LH side door inner panel. this happened to me in my integra before.
Old Jul 21, 2011 | 09:41 PM
DCRB's Avatar
K ill try another one, I already replaced the one that was in the car with a junk yard one
Old Jul 21, 2011 | 09:48 PM
el crapitan's Avatar
If you can hear it clicking, sworn is likely fine.
Probably bad ground
Old Jul 21, 2011 | 10:19 PM
DCRB's Avatar
Like bad ground to the modual in the door ya? Because none of the doors unlock or lock electronicly, the modual is what sends the +/- signal to each door lock actuator right?
Old Jul 21, 2011 | 11:59 PM
Yes. A poor ground at the control unit would cause all locks to be inoperative
tapau
Apr 3, 2019 04:00 PM
eddieE
Honda Civic (2001 - 2005)
Nov 5, 2016 01:51 PM
IVI
Apr 28, 2012 02:22 PM
PACT man
Nov 16, 2008 12:26 PM
gotbooost
Honda CR-V & Element
Oct 25, 2007 07:03 PM
