rear sway bar into 89sedan questions
Old Jul 21, 2011 | 01:22 PM
reevear's Avatar
Default rear sway bar into 89sedan questions
sorry i have looked up and down maybe i just dont know how to use the search bar to well on here but my question is
http://www.weaksauceparts.com/store/...at=2501&page=1
will this sway bar bolt right up into the car? do i have to drill through the tank to mount it? is there anyother way to do this. i recently put da integra rear discs on and now when i hit a bump it loves swaying all over.
Old Jul 21, 2011 | 03:49 PM
alex14's Avatar
Default Re: rear sway bar into 89sedan questions
I did it the nappy and ghetto way.
Parts needed:
DA rear sway bar mounts and bushings and all
sway bar
nuts and bolts
Step one:
line it up good
Step 2
weld the brackets to the frame rails of the car
Step 3:
find out where the end links touch the LCA'
Step 4:
Drill a hole there and bolt them on.
ta da!
Its ghetto and probably no where near the best way, but that is how its done on my sedan, and its MUCH better now than before.
Even better way to do it would be to get SI LCA's and put them on, but i couldnt find any to save my life.
Old Jul 22, 2011 | 11:42 AM
Tyson's Avatar
yes the ST rear bar is made to work with non Si bodies. you dont even need Si lca.
Old Jul 28, 2011 | 04:25 PM
reevear's Avatar
amazing! thanks man.
I know this is off topic how well will a da pedal fit into a ef sedan?
DoubleDirtyC
Aug 17, 2010 09:18 PM
Mikes2000civicsi
Mar 27, 2008 09:02 PM
pny1981
Suspension & Brakes
Sep 27, 2005 08:39 AM
katb16vo
22
Mar 25, 2004 03:29 PM
LCheung
Apr 18, 2002 08:01 PM
