96 accord cyl 1 miss, cant figure it out.
Old Jul 20, 2011 | 10:20 PM
doe302's Avatar
Default 96 accord cyl 1 miss, cant figure it out.
f22b1 only code it throws is cyl 1 miss. has brand new cap rotor and wires, ngk's about 4 months old.swapped injector and plug from #1 to #3 and still same thing, cyl 1 miss. tried another ecu today and still the same problem. it only misses when under a load, going up a hill even a small one at light throttle and it starts to sound like a subaru. any ideas?
Old Jul 20, 2011 | 10:30 PM
Nicefeet's Avatar
Default Re: 96 accord cyl 1 miss, cant figure it out.
EGR port clogged
Old Jul 20, 2011 | 11:06 PM
doe302's Avatar
i changed the egr valve a few months ago and as far as i could see the port wasnt clogged. what makes you think thats the problem?
Old Jul 20, 2011 | 11:14 PM
holmesnmanny's Avatar
Probably because you haven't cleaned the EGR port"s" yet.
Old Jul 20, 2011 | 11:18 PM
doe302's Avatar
ill check that out in the morning, dont understand why that would only make cyl 1 miss tho and why it dosnt thow and egr code
Old Jul 20, 2011 | 11:22 PM
Fortunately on your car it's easy to clean out the ports. You need to research what the egr system does to understand why it's making it miss.
Old Jul 20, 2011 | 11:45 PM
Nicefeet's Avatar
See this video
http://www.youtube.com/watch?v=d8N-SE047VY
Old Jul 20, 2011 | 11:47 PM
doe302's Avatar
the only thing i dont understand with this egr assumption is why would it effect only one cylinder and the same one 100% of the time.
Old Jul 20, 2011 | 11:55 PM
Nicefeet's Avatar
Because that cylinder "might" be the only one left with an open port and too much EGR gas is flowing through it. The EGR system comes online between 1500-2000 RPM BTW.
Should it be the egr ports don't be tempted to bypass the system, unless you love spark knock.
Old Jul 21, 2011 | 12:42 AM
doe302's Avatar
just cleaned it, 3 where completely clogged and one was about halfway clogged, which was cylinder 1. so we'll see in the morning what the verdict is.
kamikaze619
Sep 28, 2013 12:06 AM
hometheaterman
May 14, 2010 07:18 AM
revvin9k
Nov 8, 2004 12:45 PM
kali_guyz@yahoo
Jun 11, 2004 08:57 PM
