welded seam cracked
Old Jul 20, 2011 | 06:32 PM
jumpin4abeat's Avatar
Default welded seam cracked
So my trunk started to leak the other day when it was raining. I found the crack underneath the rubber trunk seal. It is where they welded two pieces together and over time the weld cracked. What is a good sealant to put on to seal it up? I was looking and found this stuff by JW Weld. It says that is seals and hardens enough to drill through. Would this work or is there something that is better? I tried to just use silicone, it lessened the drip but did not stop it completely.
delsolo95
12
Aug 10, 2012 08:11 PM
jumpin4abeat
Welding / Fabrication
Jul 21, 2011 12:57 PM
SRd240sx
18
Mar 10, 2007 11:11 PM
wonton2049
11
Dec 11, 2005 05:21 PM
