98 prelude with drag turbo and vafc,engine doesnt sound right
Old Oct 2, 2002 | 12:13 PM
Sincere1471@aol.com's Avatar
Default 98 prelude with drag turbo and vafc,engine doesnt sound right
i have a question. i just put a drag turbo on my 98 prelude and installed a vtec controller. im having problems ive taken it to a couple garages once to get dynoed so i could adjust the vafc and now im having problems when it starts and the engine doesnt sound right. what do you think i should do to tune it. do you think something is not connected right or maybe the problem is with my vafc. Anybody who can help please drop a line. Thanks
Old Oct 2, 2002 | 12:23 PM
LudEcrous's Avatar
Default Re: 98 prelude with drag turbo and vafc,engine doesnt sound right (Sincere1471@aol.com)
you have to be a little more specific in your details of your engine problems...does it die? does it idle funny? etc..
Old Oct 2, 2002 | 12:26 PM
apexii's Avatar
Default Re: 98 prelude with drag turbo and vafc,engine doesnt sound right (LudEcrous)
Yes, try to be more specific with the sound. Does it increase linerally as the rpms rise? Is the engine shaking more than normal? I hope it's not a spun bearing!!!
Old Oct 2, 2002 | 12:57 PM
bgod's Avatar
Default Re: 98 prelude with drag turbo and vafc,engine doesnt sound right (apexii)
what specific noises/vibrations?
what did the car put down on the dyno?
Old Oct 2, 2002 | 01:36 PM
Buckkaaaa!!'s Avatar
New User
Default Re: 98 prelude with drag turbo and vafc,engine doesnt sound right (bgod)
I once had the same setup on the same car.... did it give you power as in does it feel faster than stock?
Old Oct 2, 2002 | 06:21 PM
PrecisionH23a's Avatar
Does the engine run correctly WITHOUT the v-afc installed? If so, then you found your problem. Check the wiring, and go from there. What is probably happening is it is either getting too much or too little fuel at initial start up, you have to mess with the lo % settings. A reputable dyno shop should be able to tune this no problem if it is installed correctly. Please provide us with more specifics as mentioned prior to my post.
Old Oct 2, 2002 | 09:17 PM
ELUD THS's Avatar
New User
Default Re: 98 prelude with drag turbo and vafc,engine doesnt sound right (GudeH23a)
info and some noises would be good, if it sounds like a can of marbles., not good.
98luda
Jun 12, 2012 11:50 PM
BradleyTT(ok)
May 7, 2008 08:20 AM
reydeoro95948
Nov 24, 2007 03:27 PM
Superlude95
Apr 1, 2004 11:42 PM
