rear disk question
Old Jul 20, 2011 | 05:04 AM
wasabivtec's Avatar
Default rear disk question
I recently did a rear disk conversion on my 91 hatch. I used an assembly out of a 92 integra. Can anyone tell me if its normal for it to increase the track width? I just got it back from alignment and my rear tires stick out over an inch on each side.
Old Jul 20, 2011 | 05:13 AM
crx_si-r's Avatar
Default Re: rear disk question
did you use the original upper control arm? if you used the integra one its longer. so you may just need to swap your stock one back in.
Old Jul 20, 2011 | 05:19 AM
wasabivtec's Avatar
I used an adjustable upper arm and I used a pic lower arm for a civic hatch.
Old Jul 20, 2011 | 05:51 AM
crx_si-r's Avatar
what bout the toe arm (closer to the door)?
Old Jul 20, 2011 | 05:52 AM
crx_si-r's Avatar
sounds odd. i have 90 crx with 90 LS rear trailing arm, Blox LCA and skunk2 adjustable camber kit all the way around and i have no issues.
Old Jul 20, 2011 | 06:25 AM
wasabivtec's Avatar
I'm not positive which toe adjuster is in there. I gave the shop doing the alignment both civic and integra toe adjusters. They somehow lost the set that they told me didn't fit at all so I'm not positive which is in. I adjusted my upper arm on my own just to tuck the top of the tire in and now its got some neg camber but I'm more concerned about the toe because now its toed in with no more adjustment out. Its almost like my lower arms are too long but every set of those that I have all measure the same size 21.4 inches.
Old Jul 20, 2011 | 06:35 AM
crx_si-r's Avatar
are you sure you got the right ones? i used my stock CRX LCA then only recently bought the BLOX LCA.
Old Jul 20, 2011 | 06:52 AM
wasabivtec's Avatar
Yeah I measured the ones that where originally on my hatch and they are the same length as the PIC LCAs
Old Jul 20, 2011 | 08:33 AM
CWBETB's Avatar
Some people will tell you no. But I can tell you yes for sure. I did the swap and also pushed out my rear wheels a bit, and using all Civic parts. My buddy years ago did the swap, same thing as well. I would have preffered the CRX rear discs, I dont think they would have stuck out. FYI I had to adjust my negative camber to have my wheels fit flush "granted I am using 15x8's though, no clearence issues with a 15x6.5
Old Jul 20, 2011 | 09:47 AM
wasabivtec's Avatar
Well that's annoying...I guess ill just make my own rear arms a bit shorter
trm4life
Jun 21, 2018 08:46 AM
JDMchucko
11
Oct 25, 2010 04:43 PM
cpl rampage
Mar 9, 2010 01:23 PM
FaNiO
Oct 11, 2009 06:36 PM
