b16 LS trans outer joint bearing??
Old Jul 19, 2011 | 03:30 PM
91efbluehatch's Avatar
Default b16 LS trans outer joint bearing??
ok so i managed to pull the CV cups off the trans, and off the Int. shaft as well.
i cleaned the inside of them, and also cleaned the inside of the CV boots and the shaft themselves.
Now the outer joint bearings that slide into the cup were not in the cups themselves.
whenever i bought my swap from a friend, he pulled the axles and kept everything in baggies.
Well i go through the bag, and i see 6 bearings. 3 of them have the square plates, and 3 of them dont. I looked everywhere for these square plates, but no luck.
I called Oriellys, and also looked on Acuraautomotive. and their outer joint assemblies are over $200!!!!! does anyone know where i can order just these bearings? trying to save some money, and reuse these axles that are relatively brand new.
Old Jul 19, 2011 | 04:05 PM
Default Re: b16 LS trans outer joint bearing??
i think their called the rollers??
Old Jul 20, 2011 | 10:22 AM
sanimalp's Avatar
$cat /dev/urandom
Autozone has remanufactured axles for like $60 a side with lifetime warranty.. use the junk you have for the core for the remans.
Old Jul 21, 2011 | 04:25 PM
yea i went ahead and decided to get new axles. i said "EFF IT"
new axles will be order and installed friday.
petr0lb0mb
Transmission & Drivetrain
15
Sep 19, 2018 09:06 PM
418whpturboD
Oct 27, 2008 02:55 PM
Fly1865
Sep 24, 2006 05:29 PM
JdM_RACeR07
Aug 15, 2006 12:13 PM
skunk2powered
Sep 4, 2004 02:09 PM
