jdm dual carb to mpfi?
Old Jul 19, 2011 | 12:36 PM
civicboy420's Avatar
Default jdm dual carb to mpfi?
Does anyone know how to swap from dual carbs to mpfi? Is it the same as doing the dpfi to mpfi? thanks
Old Jul 19, 2011 | 12:51 PM
crx_si-r's Avatar
Default Re: jdm dual carb to mpfi?
it should be because your going to eliminate the carburetor manifold and swap in a fuel injected manifold.
Old Jul 19, 2011 | 01:12 PM
Ok cool, cause I already did the swap from DPFI to MPFI, Ive got wiring, ecu, dizy, and SI manifold already done, but my motor is toast so ill just pull out the old motor and install the carb one, and switch over manifolds. Thanks man.
Old Jul 19, 2011 | 02:01 PM
1990edsedan's Avatar
The cam is the only issue here. You may need to swap the dx one in.
Old Jul 19, 2011 | 02:04 PM
crx_si-r's Avatar
Also make sure to get a mechanical fuel pump block off plate.
Old Jul 19, 2011 | 02:45 PM
why would the cam make any difference? also could i use one from an SI?
Old Jul 19, 2011 | 03:08 PM
crx_si-r's Avatar
The carb cam has an extended lobe I believe for the mechanical fuel pump
Old Jul 19, 2011 | 03:18 PM
Ok so the DX one from my DPFI should bolt right in? What about the SI shaft?
Old Jul 19, 2011 | 06:31 PM
DX is fine if you are running dpfi, and are using the dfpi ecu. If you are already mpfi and have a pm6 ecu installed, then running the si cam would make better sense as the fuel map on the ecu is matched to the cam.
Old Jul 19, 2011 | 08:13 PM
Well hopefully this is the last question I need answered, If I find an SI camshaft, out of an 89-91 Civic SI, do I need the whole rocker assembaly, or just the shaft? Like is the SI shaft bigger then the DX? I do appreciate your time..
Radim
11
Feb 15, 2008 07:24 PM
Scotland:EF3
18
Jan 31, 2007 12:12 AM
crex23
18
May 13, 2005 07:49 PM
4thgenHB157
Feb 6, 2005 10:56 AM
Steve90HB
Feb 18, 2004 03:41 PM
