TRADE for a K20a:B18C1 and trans built by laskey racing and portflow
Old Jul 19, 2011 | 07:56 AM
danedoremus's Avatar
Default TRADE for a K20a:B18C1 and trans built by laskey racing and portflow
Hey Honda-tech people i am wanting to do a Kswap to my 97 teg GSR so i was wanting to see if anyone has a K20a engine to trade and cash on top or trade me right out for K20a swap that is NEWER i dont want something that has been race to hell out of.I would like the K20a to be pretty much stock.Here is the list below of what will come with the swap im sure i am for getting stuff.
contact info:269 615 2739 or pm on here to
B18C1:
81.5mm bore
12:0:1 CP pistons
eagle rods
Crank was mirco polished and balanced
OEM oil pump
OEM water pump
OEM seals
OEM sensors
OEM oil pan with PWJDM oil baffle kit
OEM head gasket
HEAD:
supertech valve train
port and polished
skunk2 pro 2 cams stage 2
skunk2 pro cam gears
Type R valve cover
OEM seals
ARP head studs
TRANS:
Wavetrac LSD
carbon lined synchros
all new bearings
all new seals
exdy stage 1 clutch-used but still brand new
type r flywheel
ARP Flywheel bolts
OTHER STUFF ABOUT THE ENGINE:
all the brackets are powder coated gloss black
i have paper work for the block
also for doing a b swap u get the following
hasport 62A engine mounts
skunk2 short shifter
shift linkage done in gloss black
New napa axles
hondata s300 with basemap to start the engine
Chasebay fuel line tuck kit
chasebays CM-2 harness
RMF knock off header
A/c for the car also comes with new o-rings and 2 new a/c lines
skunk2 intake mani
skunk2 74mm throttle body
R/c 650 injectors
Skunk2 fuel rail
power steering will come with the swap also
NEW OEM CRANK BOLT
Old Jul 19, 2011 | 12:53 PM
Default Re: TRADE for a K20a:B18C1 and trans built by laskey racing and portflow
bump
Old Jul 19, 2011 | 09:43 PM
bump!!!!!!!!!!!!!!!!
Old Jul 20, 2011 | 09:29 AM
Bump to the top
Old Jul 28, 2011 | 07:48 AM
bird00420's Avatar
are you willing to part out? i.e.: just the bottom end.........no head, no trans?
Old Jul 28, 2011 | 11:41 AM
DjSoulTrane's Avatar
Without the swap how much would you sell the entire thing for? i have a b18a1 in my 88 civi and need a swap because the motor is toast. PM me. thanks.
Old Oct 15, 2012 | 09:56 PM
ahuynh12's Avatar
do you still have your head?
OutToWinPAHC
Dec 30, 2012 04:13 PM
watisjdm
Jun 20, 2012 08:51 AM
watisjdm
Mar 29, 2012 09:19 AM
SPL Dan
Jan 15, 2008 11:10 AM
