B16a engine, ls trans, coilovers, hasport motor mounts ect. Pa
Jdm b16a with ls trans maybe 60,xxx on motor xtd stage 4 clutch, gates racing Kevlar timing belt, arp head-studs, oem head-gasket, new vtec solenoid seals from 91 nsx ( not in), pte 550c injectors. 100 miles on parts $1200 with injectors $1000 with no injectors.
Godspeed type-rs coli-overs for ef. Can adjust spring pre-load separate from ride height. only 100 miles SOLD!
Safc 2, works good bought used minor scratches, has pigtail with at least 6" of wire. $150
Hasport motor mounts b series to ef ultra race urethane for cable trans. 100 miles look brand new with hard ware. $200
Hasport linkage b series to ef, with poly mounts 100 miles $100
Chipped p28 for 550cc injectors with conversion harness obd0 chassis-obd1 ecu 100 miles (bought new from pherable) $150
Z10 catch can new hose, block plug and rear fittings to run from catch can to block. $150
Cx racing FPR kit, various fittings and some stainless hose gauge might not work. $75
Dual pillar pod for ef $15
Omni power 4bar map sensor maybe ran 15 minutes $75 PENDING!
Rear disc conversion off of 92 da. Has cross drilled rotors and new pads maybe 100 miles, mounts are filled. $200
Sandwhich for b series with feed line and restrictor, also custom made return line SOLD!
