91 b18 in a 99 civic mount question
A buddy is putting a 91 b18 ls motor in a 99 ek civic. we are trying to figure out what factory mounts we can use to get this put in. any help is appreciated, and yes..i know this is a crappy cable trans and all that...just cant find a definative answer on what factory mounts i can use to make the swap work. any info is greatly appreciated.
you can use the EKCC hydro to cable conversion to put the cable transmission in
you will need to switch the block bracket on the timing belt side to a 99-00 si and also use a 99-00 si rear engine bracket and shift linkage
phatboycrxhf
10
Aug 21, 2008 12:04 PM
insomniac791
Jan 21, 2008 04:26 PM
AudioXtremes
Jul 24, 2006 11:02 AM
