98' JDM ITR post swap questions.
i just swapped a 98' spec jdm itr into my 91' civic hatch & i have a couple questions.
i know we both had the same 240cc injectors, so is my factory fuel pump sufficient? or would a walbro 190lph be better?
i converted to ob1 and am using a chipped P08 running a replicated copy of the factory map. my friend said he chipped it for a one wire o2, but when i decelerate in gear for a couple seconds, or let off the throttle on the freeway ill throw a cel for my o2. im guessing the ecu needs 4 wire o2 still and because its not heated and the temperature changes too much when i decelerate in gear throwing the code.
thanks.
thanks.
the old school one wire o2 sensor sucks. That is why Honda upgraded to the heater sensor which gives much better readings and a better running setup
you do not need to upgrade your fuel pump for a stock itr engine
okay so i run one black heater wire to the primary o2 on the ecu, the signal to the signal, other block is switch 12v & white is ground right?
okay cool, well i think i should atleast get a fuel pressure gauge & see if my pump can throw the factory itr fuel pressure.
Markb16a
Dec 2, 2006 05:40 PM
SlippylesKB
Aug 2, 2003 11:13 AM
