New Battery Dead
Got a problem. Car is a 1996 ex running a p28 with a d15b/z6 hybrid. My battery is new and with a jump the car will run. After driving the car a short distance the batter is drained. If the car sits for a day or 2 it will start again. But then die again after a short trip.
The battery is good had it tested.
You can test it at the battery with a multi meter.
You might have something draining the car, any aftermarket stereo equip?
Did you double check to make sure it is right sized group battery? I remember I got one at Sear's and the guy gave me the wrong battery and it killed 2 alternators until I finally discovered it was the wrong battery.
your alt is not charging under full load it should be putting out over 14volts. Is the batter illuminated on your cluster? Check your wiring at the terminals to the alt if it all is okay then I would suspect that the alt has gone bad
I had it tested and was told the alt is good. I cleaned the connection for the alternator. Maybe the alternator is bad? I just hate spending 100.00 if that is not the problem.
I had a similar problem with my car. It wasn't the alternater but a bracket that holds the alternater in place broke and it would not charge my battery. I bought a new bracket and it worked perfectly.
What kind of bracket? Typically the alt has a connection and that is it.
Just makes me think, how is the belt? is it slipping, maybe the guy is referring to the alt not positioned right and not get a proper charge via the belt?
jxhxb
Dec 28, 2009 09:26 AM
