compression test, 135 across????? good or bad
Old Jul 17, 2011 | 09:33 PM
kingdomstar512's Avatar
Default compression test, 135 across????? good or bad
i did a compression test, i have 135 in each cylinder, is that good or bad for a d16y8? or is the rings about to blow? a buddy said that y8 came out of the factory with 142 in each cylinder, true or false?
Old Jul 17, 2011 | 09:45 PM
Wrona's Avatar
Default Re: compression test, 135 across????? good or bad
your friend is completely wrong that compression is not that great you should be looking at 180PSI + in each cylinder
Old Jul 17, 2011 | 09:52 PM
so does that mean my rings are gone, or is it fine for now?
Old Jul 17, 2011 | 09:56 PM
AsianCivicRider's Avatar
Thy could be. Does your civic burn oil? How does it run?
Old Jul 17, 2011 | 10:04 PM
it runs fair, it blogs sometimes, but i dont see any smoke coming from the exhaust, i have some leaks from the oil pan gasket and the valve cover bolts, but i did notice that when i pull my dipstick i have some air coming out but its not smoke, advance auto said its just my compression from the pistons going up and down, but i do have a tap coming from my engine, im replacing the rod bearings tuesday
Old Jul 17, 2011 | 10:05 PM
but it only blogged untill i hooked up my primary o2 sensor and now it runs better (someone cut the connector off my o2 sensors)
Old Jul 17, 2011 | 10:13 PM
o and to add to it the car and engine has 240,xxx miles on it
Old Jul 17, 2011 | 10:17 PM
Damn that's gonna be an involved job. And with that many miles have you considered a swap? Whether it be a d series or another engine?
Old Jul 17, 2011 | 10:21 PM
i did pick up a wrecked 97 hatch with a d16y7 in it, runs great, (yea sad i know) i was thinking about doing a swap but ppl on here said not to do it, but i was always told that the blocks are the same and just to swap out the heads
Old Jul 17, 2011 | 10:38 PM
sdr KEL's Avatar
every compression tester reads different, the way i see it is. if all cylinder read about the same or -/+ 1-10 psi near then you should be good.
Old Jul 17, 2011 | 11:09 PM
so sdr kel, your sayin that i should be good, its not like a 80 to 100 dollar tester, its just a tester i picked up from advance auto for like 25 buck or so,
Old Jul 17, 2011 | 11:57 PM
abs0Lut's Avatar
Im with KEL, if your running the same numbers across the board your fine. Think of it this way, what are the chances all of the cylinders have the exact same problem creating the exact same difference in compression, pretty slim to none if I was going to take a guess.
Old Jul 18, 2011 | 12:12 AM
thanks abs0lut...i was thinking of the same thing, i mean they all are dead on 135, and i was like 135 for all 4, there souldnt be a problem, and like i said i dont have like a 150 dollar snap on compression tester, its just a cheap one from advance auto, i do have a 97 hatch that i have, so i may just pull the plugs from that and see the compression and if they are about the same, i should be fine, im just thinking since its just a cheap tester, i wouldnt get the actually number that a shop will get but they will be in the same range thou
02BladeRider
Jul 7, 2017 05:49 AM
ef9itb
Feb 6, 2011 06:21 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
98civicEX
Apr 8, 2003 10:55 AM
